Window's 10 Guru's..help needed
So, got a new 'puter with Window's 10. lst time user and quite a learning curve from 7. Anyway, have a light that is USB powered and when I put the computer to sleep it stays on and I don't want it to. Researched it a bit and fiddled with some settings but still stays on when put to sleep....
thoughts?
Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
  • Nightfall
    Nightfall Posts: 10,084
    If the USB ports weren't powered during sleep mode how would you resume the PC from sleep mode? Your mouse and keyboard wouldn't work.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • starkiller
    starkiller Posts: 2,723
    Poo, you be right...so guess I will have to figure out how to power it w/o going into the computer..thought there might be a way to specify a particular USB to not get power during sleep....
  • Nightfall
    What's the light for? Can't you just unplug it?
    afterburnt wrote: »
  • Nightfall
    You might check your BIOS settings, see if there's something in there.
    afterburnt wrote: »
    msg Posts: 10,452
    You might be able to set the USB stuff to sleep after a while through advanced power settings configuration, and use the power button to wake the computer?
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    Use an old phone charger cube to power the light.
    billbillw Posts: 7,469
    That's a BIOS setting typically, not Windows 10. The newer motherboards have this feature for charging phones, etc.
  • honestaquarian
    honestaquarian Posts: 3,260
    1) Unplug the light
    2) Just turn the computer off :/
  • [Deleted User]
    [Deleted User] Posts: 342
    edited April 2017
    SK, I recently upgraded from Windows 7 to 10 also, so I feel your pain. Sleep mode only puts the computer into low power mode and closes the screen off. So you'll notice when you come off sleep mode any browser tabs apps you had open restart where you left them. Also your powered USB port would still have power going to it, hence your USB light not switching off. To switch your USB light off, you'll either have to disconnect it or shut down your pc. B)
  • starkiller
    Decided just to use an extension cord to run to my power center for the stereo gear and use a usb connector/adapter for the light. Don't like to shut the computer completely off as then I have to open all the sites I use during the day and to me its a PITA. I do shut it off every couple weeks to clear stuff out though...
    thanks for the help!
    Toolfan66 Posts: 17,995
    I will use windows 7 till I have no choice but to go to 10 or what ever they have at that time..
    Both of the computers I purchased in the last year came with the windows 7 disk so I could down grade if I wanted, I have a huge hate for W10..
  • honestaquarian
    I'm using a desktop computer that I built (*Three times*) and just got the new,fancy Windows 10 creators update today.
  • [Deleted User]
    edited April 2017
    Toolfan66 wrote: »
    Up till I upgraded to a new laptop with Windows 10 I used a simple patch called Never 10 which blocks the annoying Microsoft pop ups and push-updates. Works a treat.
