A good sub to pair with Signature Series?
  • ken brydson
    ken brydson Posts: 9,022
    Sickman wrote: »
    Thanks for all the recommendations! I'm good on money, so I don't really need to save. I'm still in research mode, so I can wait for a sale to pop up, just have to avoid the itch to buy now. The other day I had her play some tunes to see how much improved the sound was over our sound bar, after about an hour of taking turns back and forth she had a queue of about 10 songs she wanted to hear. I think we're going to be okay! Hahaha!
    I probably should have posted the specs of my room. I'm in a carpeted 18 x 25 x 9. Large opening to the dining room and another opening to the entryway, with the couch between to two. I've decided on sealed, for music purposes. I know ported would still be good, but I need to cut some of my options out so I don't go too crazy. So much information to absorb with buying subs!
    Keep an eye on the SVS outlet store...
    https://www.svsound.com/collections/outlet-specials/outlet-sub
  • mrloren
    mrloren Posts: 2,474
    Sickman wrote: »
    Yeah, I looked at the SB12, and just about have my heart set on it. I was actually looking at SB-1000, and then saw that. Sucks I missed the SVS clearance last year, would have been nice to get the Bill of Rights with it. Buying from a 3rd party is the only thing stopping me. My new budget bumped up to $500, so I'll be looking a bit more. Does HSU ever have sales? The VTF-2 MK5 is a possibility.
    The SB12 from Amazon is not bad, you would at least get the Amazon warranty.
    The VTF2-MK5 is a very nice sub, my older MK3 is still going strong after all these years. I am going to replacing it soon with a VTF3-MK5.
  • Upstatemax
    Upstatemax Posts: 2,797
    mrloren wrote: »
    All I can say is, both my SB2000 and SB12-NSD are better subwoofers than my old Veloydyne SPL1000's.
    The Velodyne SPL's were twice the price and had constant problems with the amps...
    I'll stick with SVS for now. B)
  • Sickman
    Sickman Posts: 6
    I went with the sb12-nsd. If I need to go big later or add another I can after I spend some time with it. Thanks again for all the help, I appreciate you guys! I'll let you know how it goes.
  • mrloren
    That should pickup your low end nicely. Please let us know what you think once it's all hooked up.
    I've had a listen to a few SVS subs and can't go wrong with them. If I had the space for two subs I would run a pair of those. For now I will stick with a single HSU.
  • mikeyb128
    mikeyb128 Posts: 2,885
    Correct me if I'm wrong, but I see no high level connections on any of the SVS subs.
    You are right. That's so strange. My SB1000 had them, I know this because I used them at one point.
    2 channel:
    Theater:
  • Mikey081057
    Mikey081057 Posts: 7,127
    Upstatemax wrote: »
    mrloren wrote: »
    The SB2000 is a great deal. Alotta sub in a compact size.
    Garage | Polk Monitor 5B's
  • rpf65
    rpf65 Posts: 2,127
    Many SVS subs have a switch to change the connections from high to low level connections. You have to check the owners manual for that info.
  • mikeyb128
    rpf65 wrote: »
    I think he means speaker terminals. And in that case I've only had them on two of the six svs subs I've owned, and that was the SB1000's.
    2 channel:
    Theater:
