I want to try a decent (inexpensive) USB cable for a portable HD
  • mikeyb128mikeyb128 Posts: 2,866
    I have a straight 7 as well. A great USB cable.
    2 channel:
    Theater:
  • vcwatkinsvcwatkins Posts: 1,873
    afterburnt wrote: »
    I found an Audioquest forest on Amazon for 35 bucks. Any opinions?
    Although I haven't tested USB cables between HD and player/computer, I have found noticeable differences in USB cables between player and DAC. A few of the head-to-head comparisons were blind tested. I would rank the ones I've tried in this order (cable, $ paid mostly used):
    WW Starlight 7 Platinum, $360
    Curious Cable $120
    DH Labs Silver Sonic Mirage $94
    WW Starlight Silver $200
    WW Starlight Red $49
    WW UV (purple) $56
    AQ Carbon $50
    AQ Forest $35
    Freebies $0
    Den: Rega RP6 * AT33PTGII * Budgie SUT * Jolida jd9 * Roon (Sonic Transporter) * PS Audio DirectStream Jr. * Joule-Electra LA-100 mkIII * Sunfire Signature II * PSAudio Power Plant 3 * MIT S3 * Polk SRS 1.2
    Office: Roon * Sonore UltraRendu (LPS-1, WW Plat7, Iso Regen, Lush) * ProJect Pre Box S2 * Pass ACA * PSA Dectet * DH Labs Q10 * Brines Folded ML-TQWT RS 40-1354
    Beach: Music Hall MMF5.1se * Speed Box II * DL103r * Lounge Copla/LCRIII * W4S Sonos * Schiit Yggdrasil * Belles 20a Pre * First Watt F5 Clone * PSA Dectet * MIT S3 * Polk SRS 2.3tl
  • afterburntafterburnt Posts: 5,486
    vcwatkins was there really much difference between the Forrest and the Freebies? Since you ranked it so low I probably won't hear much of a difference. Plus It will spend most of its time on the Oppo and occasionally on the Auralic Mini it is probably better to squeeze out a lot more nickels and go with Wireworld but they one have one USB 3.0 option
    https://store.wireworldcable.com/collections/usb-audio-cables/products/starlight-7-usb-3-0-audio-cables?variant=950479731
    Well, my first one to try was the Wireworld UV. BIG improvement over the freebies. Couldn't believe it. Slowly moved up (or sideways) after that. Probably should have skipped a few of those steps. Live and learn...
    I really like the WW Starlight Red. It's what I use for USB 2.0 A-MiniB from PC to Meridian Explorer2 DAC for MQA testing. Good value IMO, especially used. @DSkip might have a good deal on a 3.0.
    I never tried AQ Forest then switched back to cheapie, so not much help there. Also, these are all 2.0 between player and DAC (except for one phono pre ADC to PC).
    If I get a chance this weekend, I'll try one between a USB HD and PC. You've got me wondering if it might help.
  • DSkipDSkip Posts: 15,777
    IIRC, tophatjohnny reported an improvement when he got the Starlight 7 USB 3.0 cable for his hard drive.
    Thanks for the advice from all of yooz, I am gonna hold off and get it together for the Wireworld. I am hoping to squeeze a little more out of the Oppo since it is in the system that I use the most if not I will use it with the other system.
    On a side note: A word to the wise, always buy cheap crap and be disappointed I could possibly slow you down. Get good stuff and all you want is more.
  • txcoastal1txcoastal1 Posts: 10,344
    afterburnt wrote: »
    Easier, don't post questions, forum members like to spend other peoples money :)
    I got an Audioquest - Forest USB 3.0 and it is has made an improvement. Maybe it's the silver?
  • F1nutF1nut Posts: 41,802
    LOL...
    edited July 2017
    Sorry DuB. I had to.... hope you can find some humor.
  • Absolute_ZeroAbsolute_Zero Posts: 72
    edited July 2017
    I haven't had any spendy USB 3 cables. but with a Silicon Image SSD and a Belkin $14 USB 3.1 I'm maxing out a 24GB .vhdx transfer at 325MB/s. So I'm hitting the limit of my SSD.
    Hey folks I'm talking audio not data.
  • afterburnt wrote: »
    "I want to try a decent (inexpensive) USB cable for a portable HD"
    Boy, how did I ever get that wrong.
    @Absolute_Zero I should be more clear with my post however typing is not my forte. You see I have no arms or legs but I do play a mean third base.
Howdy, Stranger!
