Recapping the Monitor 5 series.
This is my first post and have a question about recapping my Monitor 5's that I just purchased. The original caps are 12uf and 34uf. I can find the 12uf easy enough but I can't find the 34uf only the 33uf. I realize that a 33uf still falls withing the specs of a 34uf even a 5% tolerance. Should I still search for the 34uf, get a 33uf or add a 1uf to the 33uf to equal 34uf? I also have the RDO194s on order so I'll be making the swap at the same time.
Thank you!
Scott H.
    F1nut Posts: 52,009
    Sonic Craft sells the Sonicap Gen I 34uF.
    Do not use a large value with a small value. If you have to use two or more caps to obtain the correct value split them evenly. For example, two 17uF to get 34uF.
  • teekay0007
    teekay0007 Posts: 2,288
    That's some pretty good math skills ya got there, Jesse. Well done! ;)
  • Faustin
    Faustin Posts: 1,151
    Many people use the 33uf since it falls within spec. Several ways to go.
    F1nut Posts: 52,009
    Back then +/- 10% was as good as it got. These days you can get +/- 1%.
  • shilmoe
    shilmoe Posts: 12
    Thanks guys!. I just ordered some 33uf caps.
    Scott H.
    F1nut Posts: 52,009
    edited March 2017
  • Faustin
    $51.00 for a cap for a Monitor5 ?
    F1nut Posts: 52,009
    That's cheap compared to many others.
  • shilmoe
    shilmoe Posts: 12
    $51.00 for a 34uf vs a 33uf was a huge determination for me. My ears are not what they used to be and with my tinnitus I'm sure I won't hear that much of a difference. I did get the new ones installed and they sound great to me. I also just picked up another set of Monitor 5s (this time the Series 2) for $50. These Series 2 were made in 1990 and have the SL-2500 tweeters. The speakers do not sound as good as the older Monitors 5s I just recapped and put RDO-194s in. They sound restricted to me, not as open. Voices seem more distant. I'm hoping a re-cap job on them will help them out. I did find that on one of the speaker that the batting inside had fallen down to the bottom of the cabinet.
    Scott H.
  • motorhead43026
    motorhead43026 Posts: 4,031
    ^^Replace the SL2500 the RDO-198.
  • shilmoe
    shilmoe Posts: 12
    198s on order should have them Friday. In the mean time I picked up a set of Monitor7s. He said they sounded great but when he drove them to the meeting place he must have knocked them around. Both drivers were locked. :# One cabinet also has some swelling of the particle board in the bottom corner. I ended up giving him $25 for the parts. The PR and crossovers were OK. I am thinking of building my own version of the Monitor 7 using MDF. Same dimensions but 1" front and back then use a nice wood veneer and upgrade it to TL status.
    I've ended up falling in love with Polks all over again. I had a set of Mobile Monitor 6502s in my car in the late 80s. The car got stolen and I never replaced them. I really miss them to this day. I'm hoping the new ones coming out this spring will be as good.
    Scott H.
