Sub to match Polk's LSiM 703s?
In the market to upgrade my subwoofer. Have a Polk PSW 505. 12 inch.
What would be a good match for my LSiM 703s? Listen to both music and HT movies.
Looking for something less boomy and able to dig more.
Or should I just buy another PSW 505? And have a 5.2 setup.
Thx!
AVR: Marantz SR 5011
L/ R: Polk Audio 703 LSiM (Bi Amp'd)
C: Polk Audio 255c - LS
R: Def Tech
Sub: PSW 505 (12 inch)
DVD: Oppo UDP 203
TV: 2016 Sony XBR 75X850D
  • rpf65
    rpf65 Posts: 2,127
    Look at SVS or HSU.
  • mrloren
    mrloren Posts: 2,473
    rpf65 wrote: »
    Look at SVS or HSU.
    what he said
  • rooftop59
    rooftop59 Posts: 8,120
    Three key questions: budget, room size, and are you willing to buy used?
    Used there are countless good options. New the brands mentioned above are easily the top two. But what we recommend specifically depends on the other two questions.
    Game Room 5.1.4:
    Bedroom 2.1
  • gce
    gce Posts: 2,158
    Call SVS and they'll recommend the best sub for your room and your wants & needs.
    Anaheim Hills CA,
  • Legender
    Legender Posts: 478
    I added an SVS SB13 Ultra to my LSiM 705s and find the mix to be extremely nice. Bet it would work with the 703s also.
    Music: Oppo103 - Parasound JC2 - Parasound A21- SDA 3.1
    Theater: Denon 3808 - B&K 7500/Emotiva XPA-3- RTi12, CSi5, RTiA7x4, PSW505
    Sleeping: Marantz 70005 - Harman Kardon 2400 - SDA 2
    2 Channel: Cary 306 SACD - Canary Audio 906 - Pass Labs x250 - PS Audio Perfectwave DAC, Polk LSiM705, SVS SB13 Ultra
    Office: Dell Optiplex, Emotiva XDA-2, Adcom 5500, LSiM 703
    Spares: Yamaha CA-810; LSi 15; Kenwood Basic M2a, Yamaha M60/M80, Polk Monitor 7, SVS SB13 Ultra
