Need matching Atmos speakers to Polk Monitors
I'm trying to find two ceiling speakers to match my current setup:
Monitor 70 Series II x2
Monitor CS2 Series II
Monitor 40 x4 (getting rid of two so I don't have to find a way to mount them in the ceiling)
I want to have two Atmos speakers in the ceiling and think I found some that would be a good match for the 70s and CS2. It is this pair: Polk Audio 80 F/X RT
Will those work or is there another pair of in wall speakers that would be better?
  • What ceiling speakers would anyone in here recommend? Trying to keep it at $300 or less for the pair.
  • codycatalist
    codycatalist Posts: 2,661
    I might be incorrect but it being a "height" speaker you shouldn't need to worry if it is timbre matched. Usually that is critical for left right and center but surrounds not so much.
  • mrloren
    mrloren Posts: 2,474
    MC60
  • I might be incorrect but it being a "height" speaker you shouldn't need to worry if it is timbre matched. Usually that is critical for left right and center but surrounds not so much.
    Good to know. Thank you!
    mrloren wrote: »
    MC60
    Placed an order for these, if they don't work out, then I can upgrade them later. Thanks!
