Musical Fidelity A3 Preamp?
tryrrthg
tryrrthg Posts: 1,896
edited October 2004 in Electronics
I'm thinking about the possibility of a new preamp. My McCormack TLC-1 preamp is a passive unit that seems to be a little thin in the midrange and sounds pretty lifeless on my speakers. I know a few people in Club Polk have experience with the MF A3 preamp and MF in general.
How would you describe the MF sound?
I think someone on here actually had a McCormack amp and MF pre, Hoosier, maybe? Any comments?
Thanks in advance!
Post edited by tryrrthg on
  • hoosier21
    hoosier21 Posts: 4,418
    edited October 2004
    MF gear = very high performance with realistic prices.
    MF does a great job of putting out excellent equipment, with great performance at an affordable cost. Like NAD, a favorite mfg. of mine for years because of the high value you get for your hard earned money, MF takes it to another level; you get better build quality, better circuitry, better performance without paying an arm and a leg.
    A3cr Preamp
    This is a fantastic pre amp and value. Everything you want is there, open soundstage with great placement both L to R and front to back, detailed highs without harshness, midrange is very nice, female vocals are awesome, nice and solid bass. You get a very respectable MM/MC phono preamp included, and it has a remote for lazy folks like me. This preamp is dual mono, with baseball size transformers for EACH channel, very overbuilt, coming in around 35lbs or so, built like a tank (it truly weights as much as an integrated amp).
    I am sure there is better, but you will PAY dearly for the small improvement.
    Not sure any of that helps, but if you have any questions give me a shout.
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • tryrrthg
    edited October 2004
    Thanks Hoosier!
    Didn't you own a McCormack amp also? If so, did you ever run the MF and McCormack together? Good combo or not? Did you run into any volume issues since the McCormack runs a little hot because it was designed for a passive pre? I had an Audio Research pre that I couldn't get to 9 o'clock on the volume dial because the gains were too high on both the Mc and AR.
    Anyone else care to chime in?
  • hoosier21
    edited October 2004
    I did not have the McCormack amp when I got the MF pre, when I had it I had the McCormack RLD-1. I have used the A3cr with MF's A3cr power amp, a couple of NADs and now my Odyessy Stratos, all without issues.
  • tryrrthg
    edited October 2004
    Thanks again! sorry for all the questions...
    How did the MF and McCormack RLD-1 compare? The RLD-1 is on my list of interest too.
    What didn't you like about the McCormack gear?
  • hoosier21
    edited October 2004
    Well the McCormack amp was sold because I made "a deal" selling both the pre and power together.
    The amp was ok, not enough time spent with it because I sold the pre. The pre was NOT my cup of tea, and this might be weird, but the digital volume s*cked, frigging 2db steps did not work for me, it might for some, but when I have to listen at very low levels when the wife and kids are asleep, 2db won't cut it.
    I have to say I did not give either piece much of a chance.
  • tryrrthg
    edited October 2004
    Something wasn't right then. All I've read about the RLD is that it goes in 0.5 decibal steps. Steve McCormack himself writes that in everything I've read...
  • steveinaz
    steveinaz Posts: 19,545
    edited October 2004
    The A3CR is characterized by its warm side of neutral sound. I think it's the perfect balance between over-analytical solid state pre's and over-bloomed tube pre's. It's definitely a good choice if the majority of your music is digital. It does all this without becoming vague or congested. All the details are there, they're just not slapping you in the face. The backgound is dead quiet. I love its simplicity and rock solid construction; it's a brute preamp weighing as much as some power amps.
    With all that said, would I pay retail for the A3CR? No. I would go $850 at most, and at that price, it better be a perfect 10 if used. I got lucky and scored mine for $635, and it's mint.
  • tryrrthg
    edited October 2004
    Thanks Steve!
    I would definitely give one a try if I could find it for that price! That is quite a deal!
  • Early B.
    Early B. Posts: 7,900
    edited October 2004
    My A3 arrived last week and it is incredible. Nothing more to add to what's already been said about it -- except that it's a gorgeous unit. The silver face with gold accents makes it look extremely high quality. That's especially important for the WAF. Very highly recommended.
    "God grooves with tubes."
  • dcarlson
    dcarlson Posts: 1,740
    edited October 2004
    I have an A3 integrated and can't see myself ever really parting with it. It's simple, effective and sounds great. I even like the dinky little remote, it actually fits in my hand.
    SDA-2a, Anthem Pre-2L, Anthem Amp 1, MF A324 DAC, Rotel RCD1070
    Senn HD650 Cardas, Mapletree Audio Ear+ HD2, Kimber KS1030, Bel Canto DAC2, M-Audio Transit, Laptop.
    F1nut Posts: 51,782
    edited October 2004
    Did somebody mention Musical Fidelity? :D
  • tryrrthg
    edited October 2004
    SHHH it's a secret! From my wife anyway... ;)
    Thanks everyone! I'd really like to give the MF a try. I'll see if I can swing it by the wife...
  • steveinaz
    edited October 2004
    Good choice; unless mine becomes unrepairable for some reason, it will be the last preamp I buy. It's that good.
  • tryrrthg
    edited October 2004
    What does the A3cr preamp usually goes for on the used market?
  • steveinaz
    edited October 2004
    I've seen them anywhere from $525 and up. Typically they top out at around $750, used. Keep an eye on ebay. You should not pay more than $700 on ebay, even for an excellent condition unit.
  • tryrrthg
    edited October 2004
    Thanks again Steve. I'll keep my eyes open then. Hopefully I can find one on the lower end of the scale to keep the wife happy!
  • Early B.
    edited October 2004
    Don't worry about keeping the wife happy. Once she hears it with her favorite music, she won't even bother asking what you paid for it.
  • tryrrthg
    edited October 2004
    I wish that were the case but she's afraid to even touch the stereo, let alone use it.
    She probably won't care too much, it's just that I've got quite a few pieces of gear that I "promised" to sell when she let me buy more gear a few months ago. The whole trial and error process is hard to swing by her...
