Reverse polarity output pre amp
Fook it.......No SDA on the Rogue pre and monoblocks then. Amphions for that set up.
I was almost there with a Dreadnaught IC. But I'll just keep it simple and reverse polarity at the amps.
But I will do more research into this phenomenon..... -
Trial and error you bid sissy! Hook them up, crank it up and see what happens. Then come back and tell us your findings. Be a pioneer.
Happy trails to you, pioneers.
https://youtu.be/ZGodtjvO5yI
I'm just across the Ohio River....say the word. -
Therein lies the confusion between terminology and topography, Ivan.
Yep just smart enough to be dumb.... -
What's your address? -
Dead bushes in the near future...
1313 mockingbird lane
