Custom Tweeters!! RDO-198's
    pitdogg2 Posts: 27,216
    waiting to see finished product
    ZLTFUL wrote: »
    While I do like, won't the stacked plates act as a small waveguide?
    my thought also. So Larry saying he wasn't done I'm reserving until I know/see more
    Toolfan66 Posts: 18,149
    The delrin and the face plate will be bonded together...
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    The outer metal circle will change the radius of the radiation of the radiant nature of the dome.....
  • Dennis Gardner
    Every change made to either the length or the angle changes deflection angles.
    They are not done yet, and this is costing me all of $27 to do this, if it doesn't work then I reverse it back to stock, but I have faith it will work out just fine!! :-)
    edited March 2017
    Keep in mind everything I'm doing to these speakers is for fun, and it's all reversible if I don't like it.. :-)
    Also it helps having something to keep my mind on other things, and my hands busy..
    F1nut Posts: 51,936
    Larry, is it not possible to entirely replace the stock plastic bezel with an aluminum one?
    edited March 2017
    That was the plan at first but when you take the tweeter apart you realize the positive and negative wires are exposed and the aluminum will connect them..
    There needs to be a barrier...
    The inside hole that you see still needs to be machined, it was lasered small on purpose for final machine as well as the four holes to be drilled and c/s, I have stainless screws for the assembly...
    F1nut Posts: 51,936
    Ah ha, I figured you'd have that answer.
    nooshinjohn Posts: 25,978
    edited March 2017
    I was thinking of something similar bu with one long piece housing all 4 tweeters... Love the look of these.
  • Moose68Bash
    Moose68Bash Posts: 3,843
    Remarkable idea, remarkable workmanship!
