Outdoor AVR, how do you do it?
  • oldrocker
    oldrocker Posts: 2,590
    I built a small wooden shelf with a handle that I just move my AVR from the pool area to the shed when I'm done with it.
    Unhooking the speakers and having to handle it each time is a pain, but something I don't mind doing.
    I've also used a small plastic tote to house it but the whole moisture thing becomes a problem eventually when left outside in our weather.
    Enclosures will also cause a problem with a remote. Nothing worse than floating 30 ft away when a good song comes on and the remote won't move the volume dial.
    I just use cheap AVR's and a cd player, if and when they go, they go.
    I like Tony's idea about that shelf in the dining area cept it's hard to make volume adjustments if everyone is outside.
    But be warned, I don't think you'll get that hellaish thunder thump of bass outside that you get on the inside >:) .
    If you do, let me know how you did that..
    pitdogg2 Posts: 27,245
    txcoastal1 wrote: »
    txcoastal1 wrote: »
    Dan are you a Libra?
    Don't think so... June 6 bday so whatever that is
    Gemini, just about the same
    So I can blame it all on that? Can't WAIT to tell my wife that's why I am the way I am... it's the DAMN STARS FAULTS!
    Yep those stars you'll be seeing once she gives you the warp factor 9 across the ol'noggin
