Infinite Baffle
my understanding is if you do dual manifolds (two sets of drivers) the back wave is actually canceled, feel free to correct me if I am wrong... so this would allow no outside sound, all inside sound...
This may also apply to a single manifold, again, I'm dangerous right now
- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Since these dont require a sealed attic, how much of the bass is carried to the outside of the house? Is this a viable option for a residential neighborhood?
Neighbors??????---Pffft---Now would it be more fun to throw on some Black Hawk Down, and have a little fun with the neighbors
With the massive subs Trey has had going in his house before at well over 105Db for hours on end? I don't think he really cares. His neighbors seem rather laid back with things. Normally, this would be cause for concern.
I had to leave the house one time when he made a huge and extremely heavy custom sub and started watching the movie Transformers at extreme volumes. I got nauseous after about 20 minutes. Yeah, it sounded good and woke the dead for miles but it was a bit much for me. Almost gave me vertigo, the sound pressure and impacts were so powerful...
My only concern would be the "advertisement" to folks driving by that something "special" was inside. Heck, I worry about that with my system. *prays*
I had to sit on that sub and add "some" ballast to that sub to keep it from walking across the floor. -
That it is, Trey.
good times, those TC Sounds drivers would of probably been a good candidate for an IB sub too...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Agreed, real shame they screwed that company up, they had a good thing going2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
True that, I really see ALOT of the LMSR driver in the new Ultimax, but I like the fact it is Dayton as I don't see them going anywhere in the event of issues...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Look at the excursion on those beasts!
Was it something like 3.5" to 4" pole to pole? -
3" peak to peak- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
....and itself.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
Shidyou not, Ryan. Better. -
The insulation in an attic would dampen quite a bit of the energy. My attic with lots of blow in stuff is like sitting in a sound chamber. Kinda deafening and weird. Under the subfloor as lots of ground and outer foundation to lower the offending waves too.
IB is a way different bass animal as you don't have to listen to a peaky, poorly designed over driven box. It is an excursion/sq. inch limited world, with most setups reaching limits under 500 watts of power.
In movies, you can wonder if an IB sub is even working as sometimes the bass is so integrated into the full range of sound that you don't notice it until you have that OMG moment when something happens on the screen and the whole house explodes.
Fun times!HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Build it and they will come
1KVA Dreadnought
Marantz SA 8005
Sony PS4
"All THAT IS LOST FROM THE SOURCE IS LOST FOREVER" -
So, I have been further researching this, the Dayton Ultimax 18 would require 4 woofers to work...
So I kept searching, FI Audio is a popular choice and their 18", a pair would work. This keeps it in my budget...
Has anyone experienced any subs from FI Audio?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Now I understand why you used so many screws.
4 of these? OMG.
It would just be two, but they could move a whole lot of air, 3" peak to peak xmax.
I have also been thinking of ways to "decouple" the manifold from the floor. I am thinking a hole in the floor that is slightly oversized, a foam gasket, and then the manifold slides into the hole and it anchored to the ground versus bolted to the joist. I am sure vibrations would still find its way to the floor, but it wouldn't be directly coupled to it... feedback?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Trey I've read they are pretty much the go to for IB. Dayton used to make a similar driver but I don't see it sold anywhere anymore."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
For the price it just seems to make sense. It sucks though because I receive dealer pricing at PE so I got a nice little chunk off the Ultimax... -.-- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
If someone could give him my email address, id buy two at a reasonable price... I'm not willing to spend $25 just to contact the guy... lol that's silly- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Ok, I finally figured it out, replied to his post...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Ive been checking used sites off and on and finally nabbed a pair of 18" IB13 FI subwoofer drivers for $295 a pair (local pick up-how lucky??)
... now to find an XTI2000 amplifier... badass sub for like $550?? cant beat it!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I think your MONSTER sub would be better, and look like furniture to boot... but thats neither here nor there
"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
yeah but one takes up 0% floor space and the other takes up like 1,000% floor space lol
txcoastal1 wrote: »Here are the pics of Matt's install
Holy cow!!! That looks awesome! How's the ceiling deal with the piston motion of the air slug in the box? -
He hasn't had any issues so far. His parents who live next door thought an earthquake was happening.2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
