Antenna Problem
I am new to the board, but nevertheless have managed to get myself a problem. More specifically, I just purchased a Denon 3805 and have a wierd problem. If I hook up an indoor antenna which came with the rig, it works great (the indoor cable is just a verticle piece of wire with no ground. However when I go to hook up my outdoor antenna with 75 ohm antenna coax, the radio does not work. If I connect the center lead of the coax to the radio, all is well, however as soon as I try to screw on the antenna, it dies. Obviously, the radio does not like to have the shield part of the coax connected. I also peeled back the shielding on my 75 ohm cable, screwed on the connector which did not come into contact with the shielding (ground) and it worked fine. I tried a number of indoor wires with no shields and a number of pieces of coax with the shields with the same results. What is going on? Help! Mel
Post edited by k2at on
The only help I can offer is switch to XM.:DOutlaw 990 Processor
Outlaw 755 Amp
Denon 2900 dvd-sacd
Dishnetwork HD-Dvr
55" Sony LCD RPTV
Lsi 9-fronts
Lsic-center
Rt55i- surrounds
Velodyne cht-10 sub
2007 Dodge Quad cab
Kenwood Excelon KDC-X891
JL Audio 300/V2
Polk Audio SR 6500 - Fronts
Polk Audio DB651 - Rear
2 -10" Treo Subs
Interfire IB 2600C sub amp
Sirius Sat radio
Ipod connection -
Switching to X/M is an option, but not a viable one as my new Denon 3805 is all of three days old. My wife might not approve.
Well,if the wife doesn't approve switch her out.:DOutlaw 990 Processor
Outlaw 755 Amp
Denon 2900 dvd-sacd
Dishnetwork HD-Dvr
55" Sony LCD RPTV
Lsi 9-fronts
Lsic-center
Rt55i- surrounds
Velodyne cht-10 sub
2007 Dodge Quad cab
JL Audio 300/V2
2 -10" Treo Subs
Sirius Sat radio
Ipod connection -
do you have cable TV ?
if so you can buy a coax splitter run one for TV and hook the other one up to the back of the receiver for radio. That is how mine is and I get channels from all over the place that a reg antenna won't give. -
I was actually going to try splitting the coax, but that won't reslove my problem regarding the receiver not wanting to see a grounded shield on the coax. As I stated in prior message, the coax works if I strip back the shielding and only use the center conductor, but when Crimp on a connector using the center conductor and the shielding (ground), the receiver goes south on me.
Where are the days when u bought a boombox and just plugged it in?
Mel -
now is the back of your receiver for a twist on coax or do you need an adaptor ? my bedroom system needed an adaptor that is not a screw on type but a push on type.
That is strange. Did you buy the tuner new? Are you sure the coax cable isn't shorted?Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Mine is for a screw on type, but I do not see where that would make a difference. The indoor antenna which came with the Denon is a push on antenna and it does work, but I believe that is because there is not ground to the indoor antenna. All it is is a piece of shielded wire with a coax connector on it.
Tuner is new and used too many pieces of coax for them all to be shorted. Tuner works great with screw on coax as long as tuner does not come into contact with the braid on the coax. I will check with Denon to c what is going on.
Mel -
sorry I didn't explain myself properly, as the connector would make a difference , but it's not the case here...hmm good luck -
Good move...Originally posted by k2at
Mel
Only thing that came to my devious little mind is hitting the jack on your AVR with a couple wraps of teflon tape as used in screwed pipe joints. It would insulate the AVR from the shielding...
Please post Denon's response...
EDIT: What's this thread doing in "Speakers"??? (Been a long time since I busted a Newbie for wrong area posting....
Welcome to the Forum, k2...
More later,
Tour...
Vox Copuli
My apologies to placing this antenna issue on this board. I am a newbie to the board and a slow learner to boot. I am pretty gud a one trial learning, so I do not believe this issue will rear its ugly face anymore. Sori
Teflon did not work as the screw on cut thru. Peeling back the braid accomplishes the same thing, but the Denon still has a problem.
When I get it resolved, I will report back, if I can figure out where to post it. HI HI
Mel
NJ -
The threaded connector is called an " F " connector.
You could strip the insulation off the ends, about an inch, and clip the shielding away from the connector. The shielding is typically right under the outer insulation. Just tape it back up to make it pretty again.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
I did peel back the shield so it does not come in contact with the F connector and the radio works great. The question though is what am I losing by not having the braid connected to the F connector??
Mel
NJ -
Nothing.
Worst case scenario, which would occur even with it grounded, would be if lightning struck your outdoor antenna.
You should use some sort of surge suppression or buffer if you are connecting anything to an outdoor strike potential.
Likely? No. Possible? Sure.
I'm being general, but I think you get my drift.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
Tnx for info and the shield and lightning. That is exactly what I thought and I purchased a tripp-lite surpressor for all the equipment including the antenna lead, but now cannot use it because of the shield problem. Life is a real bummer, then u die.
Regardless of using the shield you should employ the Tripplite unit. I presume it's a full size unit, not an adapter?
The shield is for grounding, but believe me, lightning goes wherever the hell it wants when striking, and it will certainly use that center conductor.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
Lightening is sorta like a P.O.'d rhino.
Nothing more serious than a rhino about to charge your a$$
BDT
***:D LOL:D ******WAREMTAE*** -
Mel,Originally posted by k2at
Just Polkin' a little (pun intended)... the welcome was sincere...
At least you didn't post an ebay link to your used antenna wire...
More later,
Tour...
Vox Copuli
