Not a Good Day.
  • Irrenhaus
    Irrenhaus Posts: 1,101
    Well need to start gathering lost items. So to start:
    Asus ZenPad 3S 10
    New laptop comming from work tomorrow and head to the city to get a new passport and global entry card.
    Well it is what is.....
    Cheers
    Thanks for the comments.
    Rey
    HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
  • warren
    warren Posts: 756
    May the thief's hands cripple closed with arthritis..
    Some final words,
    "If you keep banging your head against the wall,
    you're going to have headaches."
    Warren
  • Gatecrasher
    Gatecrasher Posts: 1,550
    Look on the bright side. You probably ended up with a nicer laptop!
    That's one way to get a new upgrade. Better than dropping it from a 2-story building it or submerging it in coffee. :smile:
