Are DVD-A's easy to rip?
afterburnt
I read on another forum that someone had ripped their DVD-A's but they could not rip their SACD's without going through a lot of changes.
Good question
I use DVDAudioExtractor. Works great. You can do two channel or multi-channel.
98 that looks like the solution that I need. Have you used it for blu ray?
Well the blu ray question is academic, I dont have a blu ray drive.
Same here. I rip both track versions.
"Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA
