UMC-1 7.1
musichigh
Good day everyone.
I was curious what you would use the Emotiva UMC-1 7.1 for? Is this a AVR? I just noticed it has all 7 preouts and a lot of inputs. Some advice would help if this can be used as a receiver.
Home theater processor with no amps in it. U need external amps. Easiest is a 5 or 7 channel amp, or u could use 3 two channel amps and either run a middle rear surround, bi amp the center, or just have a spare channel.Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Bedroom 2.1 Harmon Kardon HK3490; Bluesounds Node N130; Polk RT25i; ACI Titan Subwoofer
