RTI- 5 or 7--Which is better?
WVHillbilly
in Speakers
I am looking at these two about the same price.
Mostly used for HT but I want great for music also.
Need some advice here.
Running a Denon AVR.
Denon X1200W
Sony BDP S-590
Mains Signature S60
Center Signature S55
Surrounds Polk RTi-4
Sony BDP S-590
Mains Signature S60
Check s60
Do the new Polk S series sound better than RTi's?Denon X1200W
Sony BDP S-590
Mains Signature S60
Surrounds Polk RTi-4 -
WVHillbilly wrote: »I am looking at these two about the same price.
Two questions:
Do you have a good sub?
What model is the denon, does it have preouts, and would you consider an external amp?
Okay, technically more than two, but the main points are that the 7s should put out a little more more bass, but will need more power to sound their best.Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Bedroom 2.1Cambridge Azur 551r; Polk RT25i; ACI Titan Subwoofer -
I have a PSW 505 and no pre outs on my W1200X. I'm not interested in adding any amps unless they are tubes. I have a small listening area and doubt my amps go beyond 10 Watts even on peak listening.
Denon X1200W
Sony BDP S-590
Mains Signature S60
The A5's with a sub may be your best bet then.HT SYSTEM-
lsi 9's -
WVHillbilly wrote: »I have a PSW 505 and no pre outs on my W1200X. I'm not interested in adding any amps unless they are tubes. I have a small listening area and doubt my amps go beyond 10 Watts even on peak listening.
It's not about watts, it's about amperes.Political Correctness'.........defined
President of Club Polk -
Yes--I kmow it's about amperes--that is why I also have 2 old school H-K.
When I picked the Denon, because it had more features than my H-K's,I was worried about dynamic sound and amperes---My Denon sounds pretty good. Much better than a Yammie I got rid of and much cleaner than an Onkyo I sold.Denon X1200W
Sony BDP S-590
Mains Signature S60
Listened to the A5's, 7's, and 9's when I bought mine. Was at Fry's, and used the biggest AVR they had at the time, mid-range Denon. The A9's sounded like a couple of censored words, no where enough power to drive them.
The A7's, the bass sounded muddy, and the mid-range sounded restrained. Again just not enough power. They tried to sound good, just couldn't quite get there.
The A5's sounded pretty good. They do start struggling around the lower 40 Hz range, so a sub is necessary.
Duel purpose rig, keep it minimal-AVR only, go with the A5's. Some people are happy with the A7's on upper end AVR's, but I don't think yours is quite robust enough.
WVHillbilly wrote: »WVHillbilly wrote: »I have a PSW 505 and no pre outs on my W1200X. I'm not interested in adding any amps unless they are tubes. I have a small listening area and doubt my amps go beyond 10 Watts even on peak listening.
AVR's don't have much in the way of amperes, that's why adding a real power amp was suggested. Should you ever do that you'll hear what we're talking about.Political Correctness'.........defined
Since I've lived for 60 years and heard all kinds of systems I know what you're talking about and will say---Thanks for your advice and help--I pulled the trigger on a pair of S 60's.Denon X1200W
Sony BDP S-590
Mains Signature S60
SIG 60's....on that 80 watt receiver ? Your not going to get the most out of those speakers for sure. That's why we confirmed the A5's as the better choice to match your receivers power. The S60's would benefit with more than that Denon can give.HT SYSTEM-
lsi 9's -
Hope it sounds like you want.
If it doesn't, this may be the start of a new journey for you.
Or, based on your room size, this may be all you require.
Welcome to the club.Music: Oppo103 - Parasound JC2 - Parasound A21- SDA 3.1
Theater: Denon 3808 - B&K 7500/Emotiva XPA-3- RTi12, CSi5, RTiA7x4, PSW505
Sleeping: Marantz 70005 - Harman Kardon 2400 - SDA 2
2 Channel: Cary 306 SACD - Canary Audio 906 - Pass Labs x250 - PS Audio Perfectwave DAC, Polk LSiM705, SVS SB13 Ultra
Office: Dell Optiplex, Emotiva XDA-2, Adcom 5500, LSiM 703
Spares: Yamaha CA-810; LSi 15; Kenwood Basic M2a, Yamaha M60/M80, Polk Monitor 7, SVS SB13 Ultra -
SIG 60's....on that 80 watt receiver ? Your not going to get the most out of those speakers for sure. That's why we confirmed the A5's as the better choice to match your receivers power. The S60's would benefit with more than that Denon can give.[/quote
Thanks for your suggestion--don't be offended that I didn't buy what you thought would work for me. I actually wanted better speakers than the Rti-A5's.
Since Polkies think the Rti is good for theater and not so much for music, I went with Cathy's (I think that's her name) endorsement of the S60, good for both theater and music. If I find my AVR to be too wimpy for these speakers, I can always go to accessories4less and buy a more suitable unit. Right now I'm buying the best Polk's I can afford--and I did get them for a great price, I'll deal with other issues as they come up.Denon X1200W
Sony BDP S-590
Mains Signature S60
FYI, she is driving them with a powerful Sunfire amp, not an AVR. Big difference.Political Correctness'.........defined
Hey--am I getting BASHED for buying S60 Speakers with an AVR you guys do not "Approve of" ?Denon X1200W
Sony BDP S-590
Mains Signature S60
Some of you guys Take the Enjoyment Out of buying Polk Speakers. Everyone cannot afford Big 200 WPC amps and I don't see anywhere on the Polk website where that is a requirement of owning Polks. Most power specs of Polk Towers start around the same wattage ( 20 ). Some of you need to give people a break and accept that we all have different systems and different requirements with different budgets.Denon X1200W
Sony BDP S-590
Mains Signature S60
You've been given excellent advice, but in the end it's your choice. Just don't come back and say we told you so. Congrats on your new speakers!Political Correctness'.........defined
Really? That's a Left Handed compliment. So I didn't take the "Excellent Advice" and now you think I'm going to regret it. How long have you guys been on a High Horse?Denon X1200W
Sony BDP S-590
Mains Signature S60
Sigh.........Political Correctness'.........defined
Sigh.........
Really, What is YOUR problem? A new forum member comes in, wants to talk about different Polk Speakers. he gets some information, from that information, he makes a choice that you don't like--so you and tonyb tell him what a dummy he is and how he's gonna regret his choice because you do not think he's smart enough to pair speakers with his existing equipment.
So you "SIGH".
No wonder Polk has a bad reputation in other forums.
I came in open minded but have made this experience krappy for me--Thanks.Denon X1200W
Sony BDP S-590
Mains Signature S60
I'm sorry you don't like the answers to your questions, but you did ask.Political Correctness'.........defined
No--you have it backwards---I did ask and took the advice into consideration and then made MY CHOICE, which you and your friend decided to flame.
Sorry you "can't" like MY CHOICE without being an ****.
Denon X1200W
Sony BDP S-590
Mains Signature S60
Good luck to you.Political Correctness'.........defined
WVHillbilly wrote: »SIG 60's....on that 80 watt receiver ? Your not going to get the most out of those speakers for sure. That's why we confirmed the A5's as the better choice to match your receivers power. The S60's would benefit with more than that Denon can give.[/quote
I'm not offended, you asked which was better, RTIA5's or 7's.....Gave you my opinion based on your situation. Obviously it's your choice.
Now it's your turn, don't be offended if some question your choice because we have your best interests at heart. Too many times we see the same scenario with people wanting bigger speakers but not powering them correctly. They turn up the volume dial and push the receiver to it's limits and usually fry a tweeter or crossover. The members are just trying to steer you away from making those mistakes and costing you money and aggravation down the road. Like you said though, in the end it's your choice, so enjoy the new speakers.HT SYSTEM-
lsi 9's -
Now it's your turn, don't be offended if some question your choice because we have your best interests at heart. Too many times we see the same scenario with people wanting bigger speakers but not powering them correctly. They turn up the volume dial and push the receiver to it's limits and usually fry a tweeter or crossover. The members are just trying to steer you away from making those mistakes and costinge you money and aggravation down the road. Like you said though, in the end it's your choice, so enjoy the new speakers.
Thanks for your reply--I'm very much aware of powering speaking situations and under powered situations and clipping of amps which lead to frying of speakers.
In my situation, I won't be trying to crank my speakers up to reference levels.
Even though My denon is only 80 watts--it seems to have pretty good dynamics and decent amperage when compared to other AVR's I've owned. Denon and Marantz are the same company and while a Denon is not a Marantz--it's pretty close. If I find I really need more power I'll get a new Denon and sneak it in past my wife.Denon X1200W
Sony BDP S-590
Mains Signature S60
So, what is the peak to peak amp rating of your X1200W? Note, I used the correct model ID.Political Correctness'.........defined
@WVHillbilly
Welcome to the forum. The advice was good, but as stated it is your choice.
It appears you have enough knowledge not to "cook" the speakers/crossovers, but some don't and things turn south quickly. That is what the guys were trying to prevent.
You may like them with your receiver and then maybe some day try a amp and like them more or not.
It took me a while to get away from receivers and then it was another world.
Relax and enjoy the journey, can be a lot of fun.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Hi WVHillbilly,
What they were basically trying to say is that while the S60's will run on your receiver, they most likely won't operate to their full potential, which is enormous when fully powered.
So please be careful with the volume knob, and maybe plan to get a separate amp in the future, providing you have preouts on your current receiver.
You are in for a treat when you get them, I am loving mine!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
If you're just here to pick,pick, pick, go somewhere else.
I really do not need your negativity.
Denon X1200W
Sony BDP S-590
Mains Signature S60
I was curious as to the peak to peak amperes rating of your AVR since you said it was decent, so I tried to find that information, but was unable to. Since your response to my legitimate question resulted in yet another attack I can only presume you have no idea what it is.Political Correctness'.........defined
