Is there any thing that I could have screwed up
try1256
when I re-capped my SDA 2a crossovers that would cause a hum when I connect the SDA Cable? Thanks
Tim
Tim
Sure, you may have a cold solder joint, you may have put a lead in the wrong place, you may have broken a lead on an inductor.......Political Correctness'.........defined
President of Club Polk -
Thanks Jesse, I did change the SDA inductors. Are they polarized in any way? When I installed them, I don't recall seeing any indication that they were and I am not sure if I wired them identically.
Are you certain you are using a common ground amp with your SDAs?
- SDA 2BTL · Sonicaps · Mills resistors · RDO-198s · New gaskets · H-nuts · Erse inductors · BH5 · Dynamat
- Crossover upgrades by westmassguy
- Marantz 1504 AVR (front speaker pre-outs to Adcom 555)
- Adcom GFA-555 amp · Upgrades & speaker protection added by OldmanSRS
- Pioneer DV-610AV DVD/CD player
- SDA CRS+ · Hidden away in the closet
Yes. It is commong ground. Odyssey Khartago
