Soundproof a pocket door
I'm planning to install a pocket door on our "game room" which is where I mostly listen to tunes. I think I will build a hollow core door and fill it with sound deadening material. Considering that the door cavity will be 1.5" wide at most, what would be the best material to use? Roxul?
Yep, my name really is Bob.
Parasound HCA1500, Dynaco PAS4, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Oppo BDP93, "upgraded" Polk SDA 2B.
  • VR3VR3 Posts: 22,940
    I have solid core doors through out my house, blocks sound real well
    - Not Tom
    Vr3Mods.com ///// Version3Audio.com
    "No, that's silly talk. Dude, you can't possibly be this audio dumb so quit the act." - Doro
  • mrbironmrbiron Posts: 4,963
    VR3 wrote: »
    ^^^This. By the time you buy all material associated, you could have bought a slab and been done in an hour+-.
    Pocket doors probably aren't the tightest meaning there is the untreated void in the wall cavity where sound can easily travel. Maybe you can gasket that as well???
    Zu Audio Omen MK-1B's, Peachtree Decco65, Bryston BDA-2, Cheap TT, PS Audio UPC200, PS Audio AC3's, Zu Mission SC's, HTPC, One, Bottlehead Reduction & Crack w/Speedball
  • muncybobmuncybob Posts: 2,016
    Yeah, I should have sealed that cavity and installed the pocket door when the walls were open.
  • DaveHoDaveHo Posts: 2,187
    Mass & an air tight seal are what determines the STC of any particular surface. Is an air tight seal even possible on a pocket door?
    DaveHo wrote: »
    You'll never achieve the seal on a pocket door but you can at least slow it down...possibly.
    There aren't any systems, that i know of, but some mickey mouse rigging can be deployed.
  • Joey_VJoey_V Posts: 6,877
    Not sure you can really seal a pocket door
    Joey's Gear:
    Current Gear:
    Torus RM15 -> Emm Labs DAC2x and TSDX Transport -> Cary SLP-05 preamp -> Boulder 2060 stereo amp (w/ Audioquest WEL Signature) -> new speakers
    Rotel RA1592 Super Integrated -> Sonus Faber Olympica 3
    Rotel RC1570 preamp -> Rotel RB1582 amp -> Focal Kanta 2
    Old Gear:
    Speakers: BW PM1 (3.5/5), CM10s2 (3.75/5), BW800D3 (5/5), Rockport Aviors (5/5), Sonus Faber Stradivari (5/5), BW 802D2 (4.5/5), Martin Logan Summits (4.25/5), Martin Logan Vantage (4/5), Sonus Faber Cremona Auditor (3.75/5), AV123 Strata Mini (3.5/5), ML Mosaic (3.25/5), Onix Ref1 (3/5), Sonus Faber Concerto (2.75/5), SF Concertino (2.5/5), Axiom M22ti (2/5), Polk LSi9 (3/5), LSi7 (2.9/5)
    Source: Squeezebox 3 -> PS Audio Digital Link III -> Cary 306/200 CDP -> Cary 306 SACD -> EMM LABS DAC2X/TSDX
    Preamplification: Rotel RC1070 -> Rogue Perseus -> Cary SLP98 -> Cary SLP98F1 -> Cary SLP05 (sold and then repurchased)
    Amplification: HK AVR330 -> Rotel RB1070 -> Rotel RB1090 -> Plinius SA102 -> Cary 211FE -> Classe M600 -> Boulder 2060
    Subwoofer: Infinity Entra2 sub -> SVS 25-31PC+ sub
  • DSkipDSkip Posts: 15,591
    Joey_V wrote: »
    I've seen enough Sci-Fi movies to know that you can. >:)
    audiothesis.com/
    Speakers: Harbeth: 30.2, SHL5+; Usher: Be-10, T-515; Rosso Fiorentino: Elba, Pienza, Certaldo, Fiesole, Volterra; Polk: T50, Signature S15, RTA 15tl, RTi12; Sonner Audio Allegro Unum, Legato Unum, Legato Semis, Legato Duo; Emerald Physics CS-2.8; Klipsch KLF-20
    Preamps: Shuguang S200MK, Dayens Ampino, Parasound P5
    Amps: Shuguang S845MK, Dayens Ampino Monoblocks, Parasound A23
    Integrateds: Triode Corporation TRV-88SER, MastersounD: BoX, Dueventi, Compact 845, Evolution 845; North Star Design Blue Diamond
    Sources: AURALiC Aries, Denon HEOS Link, North Star Design: Magnifico, Supremo, Incanto, Intenso, Venti
    Cabling: Wireworld
    TV: Sony XBR-75X940C
  • K_MK_M Posts: 1,304
    Star trek did it....right?
    I would use a solid core door. Big difference in sound not being able to penetrate, but it will still get around the edges or gap easily.
    Our media room in our one house has a pocket door, and it was not really able to be effectively quieted enough, even with the Solid core heavy door.
    We Eventually installed a 2nd solid core swinging door, about 6 foot down the small corridor that led to the media room, that could be closed when almost total quiet was needed. That made a huge impact in reducing most all of the sound.
    So like dual doors, spaced about 5-6 feet apart and we just leave both open usually unless we have some fairly loud movie going.
    At first it was cumbersome, but now we grew used to the look of that set up.
    Lsi15, Lsi9, LsiC,Rta11t,M5jr+,M4,SDA 3.1TL, SDA SRS 2.3TL, Rti6....Still listing stuff, a work in progress.
    B+W-Sold
    Epos-Now gone
    Infinity-Sold
    Advent-Now gone
    Yamaha A-S801
    Yamaha RX-V377
    Yamaha RX-A860
    Yamaha RX-A3060
    Harman Kardon Hk-350i
    Harman Kardon Hk-........
    Harman Kardon PM-665
    Harman Kardon HK-775
    Pioneer.......Stereo Receiver
    DSkip wrote: »
    Joey_V wrote: »
    Poisonous gas is one thing.....sound quite another.. :#
    B+W-Sold
    Epos-Now gone
    Infinity-Sold
    Advent-Now gone
    Yamaha A-S801
    Yamaha RX-V377
    Yamaha RX-A860
    Yamaha RX-A3060
Howdy, Stranger!
