How to play a Mac 3.5" floppy disc?
[Deleted User]
I have a Macintosh 3.5" floppy disc that is formatted in Mac DS/DD arrangement. What would I need to add to my current Mac computer to be able to run this?
Thanks for any assistance.
Cheers, Ken
Cheers, Ken
Thanks, I sent him a PM...!
Ken, simple, easy...however cheap at your own discretion,
https://www.amazon.com/USB-Floppy-Drive-External-Portable/dp/B01LYMOWIE/ref=sr_1_2?ie=UTF8&qid=1487816887&sr=8-2-spons&keywords=floppy+drive&psc=1
I think its the old outdated MAC format that is the issue2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
txcoastal, if he's running a Mac all he would need is a floppy drive to read the disk. Apple hasn't dropped floppy reading from OS-X however they have dispensed with the drives.
However, the 800K Macintosh format (also on DSDD diskettes) needs a special floppy drive with a variable speed.
USB/Floppy Drive
Data Transfer Rate: 250 Kbits (720KB) / 500 Kbits (1.44MB).
Number of Cylinders: 80.
Rotation speed: 300 rpm, 360 rpm recording method: MFM.
Media: High Density (2 HD) or Normal Density (2 DD).
Acerage Latency Time: 100 MSEC (1.44MB mode) 83.3 MSEC (720KB mode).
2. Can not Work with OS X El Capitan on a 2015 MacBook Pro.2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Is this for lossless playback? Redbook may be matching toward outdated, but you're digging WAY back...
It was a well thought out program that analyzed speaker placement and predicted frequency responses. It was called Visual Ears or The Listening Room and it was easy to use and was really helpful. I used to have people give me the dimensions of their room and then I'd figure out where the best speaker/subwoofer placement should be and then give them the measurements. But I don't have the old Mac to run it any more. I found one data retrieval company that will convert it to a more modern format but they have a $175.00 minimum charge.
Ouch2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
That's what I said.
Is it just the disk that's the problem, or is it the software, too?
Will that piece of software run on your newer Mac if you can just get the disk's contents onto a flash drive?Jay
To the best of my knowledge the program works fine the last time I tried. The difficulty is that the 800k double discs require a variable speed player and the correct software to run the player. There's nothing that can be added to a more recent computer that can accomplish this. You have to use an older Mac with the older player. I've a friend (wife's friend actually) who is a certified Mac-tech that is able to look at it.
Just read up on that format. Significantly old machine needed to read that disk!
I've got an ancient iMac with OS old enough to read it, but no drive that's capable of feeding it to the iMac!
I hope your wife's friend is able to put you in business.Jay
