Need quick advice!
Looking at a used but looks to be old ps audio power director. 400$ worth it? u9pj3gf403zq.png
2 channel:
Theater:
  • Willow
    Willow Posts: 11,244
    Looks like it is floating on the carpet.... Groovy
  • mikeyb128
    mikeyb128 Posts: 2,885
    Well no quick advice happened here. I passed on this due to age.
    2 channel:
    Theater:
    F1nut Posts: 51,912
    Sorry Mike, I wasn't familiar with that one.
  • mikeyb128
    The seller seemed annoyed I asked how old it is. First sign to abandon the deal.
    2 channel:
    Theater:
    I could be mistaken, but if I recall, that particular model had some issues. I'd pass...
  • mikeyb128
    tonyb wrote: »
    I picked up something different. And a little out of the box. But made in 'merica and built like a tank.
    http://www.corepowertechnologies.com
    http://www.essenceelectrostatic.com/product/core-power-technologies-equicore-1200-1800-fully-balanced-ac-power-source/
    2 channel:
    Theater:
  • Joey_V
    Joey_V Posts: 8,603
    What is that
  • kharp1
    kharp1 Posts: 3,453
    tonyb wrote: »
    I seem to recall the same thing...something about shutdown issues if I remember correctly.
  • mikeyb128
    edited February 2017
    kharp1 wrote: »
    tonyb wrote: »
    My research shows it's from 2002... so naturally I blew my budget by about 3 times what I wanted to spend. Should be good enough :sunglasses:
    2 channel:
    Theater:
  • gurot1
    gurot1 Posts: 519
    Isn't blowing your budget what this site is all about? :)
    lsim705,lsim706c,lsif/x(4)+mc80(atmos)
    rti6,csi5,fxi5
  • kharp1
    kharp1 Posts: 3,453
    Hey, quit picking on me!
    Cool man, looks beefy. Let us know how it works out when you get her in the door.
  • mikeyb128
    Will do! The reviews on the smaller 300 model all look very promising. I will be using this to run my front end gear, I will experiment with plugging the amp into it. It was recommended by the dealer here in Canada to do so, and he did actually used my amp in one of his experiments. In my experience I'm likely to leave it plugged into the wall, but we will see. Should have it by the end of the week, just in time for the weekend.
    This is a demo unit as well, which is just broken in. I'm told it should stabilize at the 48hour mark.
    2 channel:
    Theater:
