SDA terminal plates and upgraded IC cable source?
Having gotten the 2.1s home, the only thing they seem to need are the metal terminal plates and the upgraded interconnect cable.
Can anyOne direct me to the thread(s) for these items?
Thank you in advance:-)
― Aleksandr Solzhenitsyn
Best Answers
Answers
  • vmaxer
    vmaxer Posts: 5,120
    What are 2.1s??
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • vmaxer
    vmaxer Posts: 5,120
    la2vegas wrote: »
    I believe that the original poster is suffering from SRS giggles. Not sure but I believe he meant 1.2's, not 2.1's.
    It's understandable since he just struck gold high atop the Colorado Rockies.
    Understandable.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • daddyjt
    daddyjt Posts: 3,030
    vmaxer wrote: »
    What are 2.1s??
    Yup - 1.2 - sorry :blush:
  • daddyjt
    Plates ordered - thank you!
  • daddyjt
    Ok, I have the plates on order (thank you @vmaxer !), and I have the speakon plugs and bases on order as well. What kind of wire to most of you use for this cable? Gauge? Any sonic advantages to silver vs copper?
    Thanks again for all the help...
  • daddyjt
    dkfreebird wrote: »
    Same cable you use for speaker cables. I made mine of the kimber kable I use for speakers.
    Damn - I was afraid that was going to be the answer....!
  • Nightfall
    Nightfall Posts: 10,084
    What speaker cable are you using?
    afterburnt wrote: »
    Village Idiot of Club Polk
  • vmaxer
    vmaxer Posts: 5,120
    daddyjt wrote: »
    dkfreebird wrote: »
    That is no doubt the best option. I haven't gone that far......yet. Some day.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • daddyjt
    Nightfall wrote: »
    I was using Kimber 8 TC, but I recently switched to MIT Shotgun S3.
  • dkfreebird
    dkfreebird Posts: 1,186
    edited February 2017
    OUCH! :#
    Polk 1.2tl's Modded with dreadnought
    Musical Fidelity M6Si
    North Star Intenso Dac
    Auralic Aries Mini Streamer
    Oppo 103
    Pangea PC
    Wireworld Equinox 7 interconnects
    Wireworld Equinox 7 Speaker Cables and Jumpers
    Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5 peerless,Polk R200,McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre
  • Nightfall
    I know Jesse called MIT and they sold him plain Shotgun cable. He said it was a PITA to work with
    afterburnt wrote: »
  • vmaxer
    vmaxer Posts: 5,120
    Nightfall wrote: »
    I wonder if they would terminate a set with SpeakOn?
    I then wonder if one could afford it????
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • daddyjt
    vmaxer wrote: »
    Nightfall wrote: »
    Yea - just because you can, doesn't mean you should... :smiley:
