Opinions and insight requested - best next upgrade? Rotel RSP-1068 Pre or Polk LSi7
dvdchance
dvdchance Posts: 13
edited October 2004 in Speakers
I'm new here on the Polk board, but have had polk spkrs for a while now. Am hooked and plan on staying polk.
Here's what I currently have:
Denon 2805 - receiver
Rotel RMB 1075 - 5 ch amp
Polk rt35 - Front spkrs
Polk CSi40 - centre spkr
Polk FXi3 - Surrounds and Surround backs
Velodyne DLS 4000 - Sub
The Rotel amp is only a week old, and the difference from using the receiver amps to the 1075 has been nothing short of ...wow. So much more depth in the sound.
Seems to me the weakest link by far now is my front speakers.
So would upgrading my mains to say LSi7 or LSi9 be a better move for me then going to a Rotel RSP-1068 pre replacing the receiver.
Since i can't upgrade all at once, which would be a better path?
LSi7 or 9 now then RSP1068 eventually LSiC and surrounds
LSi7 or 9 now then LSiC and surrounds then RSP1068
Will the LSi fronts sound good with the polks I will still have, the CSi40 and FXi'3s?
Part of my thinking is that the sooner I get the 1068, the more I can get selling my Denon 2805 on Ebay.
My usage is probably 75% HT and 25% music.
david
HTS System
Denon 2805
Rotel RMB 1075
Denon DVD 2910
Polk LSi7 Front
Polk CSi40 Centre
Polk FXi3 Surround and Surround Back
Velodyne DLS 4000 Sub
Vintage System
Pioneer SX-890
Pioneer CT-F7272
Dual 1219
Post edited by dvdchance on
  • Sami
    Sami Posts: 4,634
    edited October 2004
    If I was in your shoes this would definately be my choice. At least the three front speakers before the prepro. Music will be much better with the new fronts.
  • okiepolkie
    okiepolkie Posts: 2,258
    edited October 2004
    I upgraded from RT5's(basically the same as Rt35's) to LSi7's and noticed a huge difference, even though I'm just using a Yamaha receiver.
    A good preamp will make your current system sound pretty good.
    The LSi's will also make your system sound pretty good.
    The least expensive approach initially would be the LSi7's. They can be had new and used between $300-400. After that, you decide if your center channel will work. If you can't tell a large difference, then skip the center and go for the preamp. I have heard a couple people say their CSi40 sounds ok with the LSi's.
    The surrounds will probably tide you over the longest. I have FXi30's and in my listening room, they sound fine with the 7's.
    Are you going to use the RT35's as rears in a 7.1 system(sorry I don't know the specs of the preamp you are considering?
    Have fun with your upgrades. I'm enjoying mine.
    Tschüss
    Zach
  • Emlyn
    Emlyn Posts: 4,824
    edited October 2004
    David,
    Your receiver should hold its value pretty well for the next couple of years since it's a recent model. Your speakers won't continue to hold their value. I recommend selling the front and center speakers you have now and suggest purchasing LSi9s and an LSi Center as your next upgrade.
    I have an RSP-1068 and it is a significant upgrade to a receiver, but I think the best way to build a system incrementally is to buy the best speakers you can afford first and then build the system around the speakers. I suggest using your Rotel amp to bi-amp LSi9s and use the spare channel for the center. Use your receiver's internal amp for the surrounds.
    Your FXi3 surrounds will sound fine with LSi speakers up front, but you won't want to use the CSi40 with LSi speakers as the mains. They don't sound right together.
  • cfrizz
    cfrizz Posts: 13,415
    edited October 2004
    You should go for LSI 9's first, then later on down the line get the RSP 1068. The Denon can hold its own for now.
  • dorokusai
    dorokusai Posts: 25,576
    edited October 2004
    LSi9.
  • malikarshad
    malikarshad Posts: 527
    edited October 2004
    I have LSi7 & Rti70 up fronts with CSi40 and I'm happy with it. But I plan to upgrade to LSi15 & dual LSi7 (will be Center) in the near future. I use Denon 3803 as a preamp and Outlaw 770 is the amp.
    I think you should go for speaker upgrade with LSi9 and LSic to hear a noticable difference in SQ.
    Speakers=>Salk Soundscape 8, Soundscape Center,Surrounds-Dali Rubicon LCR, Lsi7
    PreAmp, Amp => Marantz AV8801, ATI 6007 amp, Oppo HA-1 DAC
    Source => Sonore MicroRendu, Oppo BDP-103, Mede8er 600XD, Dune HD Smart D1, Synology DS1813+(16TB)
    Sub - JTR Captivator S2 (Dual 18")
    Power - Furman IT-Ref20i on dedicated 30Amp circuit with Furutech GTX-R outlet
    Screen=> JVC RS-45 projector Da-Lite HP 133" 2.35
  • Toxis
    Toxis Posts: 5,116
    edited October 2004
    LSi9's, then LSiC, then Preamp, then Surrounds. Unless you listen to a lot of DVDa and SACD then I'd do the surrounds before the Pre...
  • Frank Z
    Frank Z Posts: 5,860
    edited October 2004
    Lsi9's AND the LsiC. Save your coinage until you can swap out the front three.
