2.3 TL Blackhole 5 placement
New to the forum and I'm ready to do some mods to my 2.3 TL's. I've got a set of Larry's rings, Dynamat, Armacell, Loctite power grab, and Blackhole 5, and planning on doing the work this weekend. My question is on the Blackhole 5 placement. I understand placing a 3 inch wide strip behind the 4 MW's from the top speaker to the bottom one, but on the 2 SDA effect speakers should I place a full strip the same length as one behind MW's or one just long enough to go from top to bottom of the 2 speakers. Also should there be a strip on the side and if so how long
    F1nut Posts: 51,938
    I did mine just behind the drivers, none on the sides. A little of BH5 goes a long way.
    Toolfan66 Posts: 18,154
    edited February 2017
    I made 4" strips for my 1.2tl's, I made them the length of the driver configuration, and placed them on the back wall behind the drivers..
    F1nut Posts: 51,938
    Mine are 4" as well.
  • Thanks F1nut and Toolfan66. That should give me enough left over to do my 2A's.
    F1nut Posts: 51,938
    I had plenty left over after doing the 2.3TL's.
  • I cut 3' strips for my 2Bs and this probably the 2nd best audible improvement. 1st clearly was changing out the SL2000s to the RD 194s and then the BH-5 worked so well I was even considering taking it out because it tightened up the sound so much I was a bit shocked. My Dynamat came free from a stop at a car shop place and had a load of unused shards I collected and then the B-H-5 I got a cheap sheet off C/L near me.
  • 1st clearly was changing out the SL2000s to the RD 194s
    Tweeters are the next mod for me($). Mine are discolored, one dome is black, and the others are silver, but the silver has wore off on the higher parts of the domes leaving them transparent. Glad to hear they made such a difference in your speakers
  • drumminman
    drumminman Posts: 3,396
    I placed 4" wide strips of BH-5 on the back wall of my 2.3tl's to the bottom of the mw's, none on the sidewalks. I also repositioned the polyester batting. An easy tweak with very positive results.
  • @F1nut
    Do you still have the blackhole5 and would you be willing to part with it?
    F1nut Posts: 51,938
    I give some away and the rest I need for another pair of speakers. Maybe you can find someone to go in halves with you.
  • muncybob
    muncybob Posts: 3,262
    My 2b's have had most mods done with the exceptions of going TL and the BH5. Is the BH5 in addition to or in place of the stuff that came from the factory?
    Yep, my name really is Bob.
    muncybob wrote: »
    Addition to the poly..
  • drumminman wrote: »
    Thanks drumminman, I just remember seeing a discussion where the poster had put it on the sidewall
    Drahthaar wrote: »
    drumminman wrote: »
    I put it on the side wall, but it is not needed..
  • muncybob
    Looks like I'll be doing this next time I open up the 2B's. I'm clear that 4" strips are adequate but exactly where do I start and end the strips?
    F1nut Posts: 51,938
    Just behind the mid-drivers.
    muncybob wrote: »
    It's like this, I have the 1.2tl's I have two strips 4" wide starting from the top of the top driver (mid) to the bottom of the bottom driver (mid)
  • muncybob
    Just ordered some BH5, should be here inside of a week.
    Why the 4" size? Why not the diameter of the drivers? I guess I'm not real clear exactly what the BH5 is doing to the sound.
    pitdogg2 Posts: 27,218
    I believe in a nut shell. Behaves like the cabinet is bigger than it is. Too much and it seems to suck the life out of the sound
    F1nut Posts: 51,938
    ^ BINGO ^
  • muncybob
    I have read that cutting the BH5 with a table saw produces the cleanest cut. Would it be cut with the adhesive down or up?
    Looking back at DK's write up on BH5 I see he installed also on side walls and behind tweeters. This was done some time ago so I'm sure there has been some experimenting since then. It's been mentioned sidewalls are not needed to be treated, but what about the tweeters?
    F1nut Posts: 51,938
    Down because it slides better on the table.
    Tweeters don't have a backwave.
  • muncybob wrote: »
    I cut mine with a bandsaw. It did a great job with very little dust/waste. And definitely adhesive side down.
    But like you I saw what DK had done and I put some BH5 behind the tweeters. I wonder how hard it is to get that stuff off. I should have listened to F1nut and Toolfan66
  • muncybob
    It would appear that I will have plenty BH5 left over so if anybody wants to work out something on what they may need, PM me.
    I'm glad I stumbled on all things BH5 here as I'm sure I would have gone overboard otherwise. Looking forward to yet another beneficial tweak.
    gudnoyez Posts: 8,174
    I would take some off your hands where would you place it on CRS+'s since the Passive is located in the back?
    gudnoyez wrote: »
    http://forum.polkaudio.com/discussion/172176/sda-crs-with-an-external-crossover-twist/p1
    Go to page 7 scroll down, and you can see the pieces of wood I put in place to mount the BH5 on, worked perfect..
    A couple other guys did something similar..
    Thanks Larry @ muncybob incoming PM.
  • muncybob
    OK, I hate to be a pain here but in carpentry you measure twice and cut once, so I'm just wanting to be sure of what I'm cutting here. I'll be going with the consensus that the BH5 should be 4"....should the strips be 4X4 or closer to the actual width between the center brace that is between the mids on my 2B's and the outer wall which would then make them 4X6....maybe that 2" difference is nothing to worry about?
    I would cut them 4 x 6 put them on the back wall directly behind the drivers..
    So you would need 4 pieces cut 4 x 6, and put them so the 4" is across, 6" top to bottom..
    Of course you can try it how ever you want, this is just how I would do it..
  • muncybob
    So I did install the BH5 exactly as Larry describes. I'm amazed how a small patch of this material makes this kind of difference. I don't have golden ears anymore...maybe not even bronze, but to me the vocals seem more "realistic" and somehow the low end is more pronounced. I listened to several cd's that I'm very familiar with and previously some of the details I sorta had to really listen for where now it seems the detail is effortless...if that makes any sense?
    Now I'm chomping at the bit for my tube pre to return and do some chillaxin'.
