Cardas thruholes.... 1/2" or 13 mm?
xschop
Starting a set of thick billet plates and have generic gold posts that require 1/2" holes. Figured I want to drill for Cardas Incase of later upgrade and I sell the spare set.
Has anyone installed the interlocked Cardas plastic bases in alloy?
Best Answers
The Cardas CC series binding posts, like the CCGR s you would need to drill the metal for the two 1/2" holes. Here is a link to our Cardas CCGR s binding posts, and there is a drawing showing all the dimensions. Hope this helps.Sunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
http://www.douglasconnection.com -
Yes, they make the same binding posts with a longer shank size for thicker materials. We keep the s (short) ones in stock, but have the L (long) ones available if that's what you need.
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
That's a good tech drawing and answers another question. The 5/16 thread allowed me to use a common 5/16" ID Teflon tube/sleeve thru the 1/2" alloy depth on my last set. Thanks again.Don't take experimental gene therapies from known eugenicists.
That's a good idea. The knurled area continues directly into the threaded area at 0.240" dia.
Yep I've used them in the past. Good post's for the money
Answers
Thank you, the fleabay ones I looked at had a 0.513" dimension and I thought they could be china knock-offs.
On another note my plates will machine 1/2" thick with 1/4" step for inset. Do they may a longer set like yours in link above?
Thanks for your help.Don't take experimental gene therapies from known eugenicists. -
The odd stainless tapered set screws finally showed along with my Neutrik inputs....
Another question or two...
Since these generic posts don't have set screws for the inner wires, is it kosher to simply use an eyewasher style crimp and bolt them down from the inside once they are attached to the plate to avoid soldering to the gold plate?
Also does it matter which pin/blade wire goes on either Neutrik pin?
Post edited by xschop onDon't take experimental gene therapies from known eugenicists. -
You are suppose to use M3 (3 millimeter) screws/hardware for the Neutrik sockets and you should have used the 4 pole high current version.
Solder those connections.
One should be marked + and the other -.
President of Club Polk -
OK, solder it is.
I went off the tech drawing I found for the nl2mp showing the hole diameter at 0.138" which happens to the major diameter for 6-32 screws. There's no slop in the sidewalls and the taper fits snug.
I haven't read any threads yet for Neutrik line replacement for the interconnect cable. I'm not sure if pin/blade inputs from factory crossover matter assuming I build the cable to match. Or is the Neutrik cable shielded for main signal?Don't take experimental gene therapies from known eugenicists. -
OK. I had some extra coffee, read some more diatribe and didn't see any shielded jargon. Couple clicks and I have a new 10ft pre-assembled 15g Speak-on connector on its way.
I'll only be pushing 80wpc thru these CRS rarely, and I did see where you guys were using the 4- pin connector on the Big SDAs. That's good info to know. Thanks again. F1 is a pleathora of knowledge.Don't take experimental gene therapies from known eugenicists. -
Ok, see how your screw heads are proud of the flange? With M3 screws they sit flush.
Another tidbit while we're at it. Only some of the Neutrik sockets are air tight, so folks need to check on that before ordering.Political Correctness'.........defined
Proud by 0.035"
I just pressure tested them, no leaks thankfully.
Im line boring the ID of the plates for each Neutrik with a 0.0005 interference fit.
All of them are within the tolerance of the Neutrik drawing, but I ruminate over my machine fitment like you guys do for your binding posts.Don't take experimental gene therapies from known eugenicists. -
This is with M3 screws/hardware. Zoom in for a better look.
Hey that doesn't have any binding posts, hehe.
Nice work. I think I'll keep these tapped standard with the socket heads. I just saw the Vr3 plates with dome heads?Don't take experimental gene therapies from known eugenicists. -
Ok I used the search here and I cannot find the pics of the custom billet plates someone had done I believe in stainless. Anyone familiar with those?Don't take experimental gene therapies from known eugenicists.
That was nikonik and they are aluminum.
http://forum.polkaudio.com/discussion/170771/a-year-in-the-making-of/p1
Thats them. Thanks, I wanted to see how close the posts are to the tapered walls before I cut mine. I dont think I'll inset mine at all due to my large thumbs and the scarce real estate there. Also his cab mount holes are a little larger than factory as well. Im CNCing mine to step them out a touch further so the larger holes drilled in the cabs have more MDF and the hurricane nuts clear the ID of the large factory thru hole.Don't take experimental gene therapies from known eugenicists.
Got some free time to prog the CNC. so I can make them on lathe or mill depending on what size material materializes later...
Had to make special vice jigs just for these... A 0.25" mounting lip will never bend no matter how thick the armacell is hehe...
Is the standard hurricane nut used on the old Polks 8-32 ?
I see something beautiful in the making.
Yes, 8-32.Political Correctness'.........defined
Thanks F1. These will be trick. As you may see the flange is also a touch wider and holes also on a touch larger radii for the hurricane nuts and bolts to hold more formaldehyde and sawdust....
I'm tapping and facing them with the same finish as the silverface knobs and billet feet I recently made.....
The shop lights and phone camera have grievances ..
Ok, this is looking different than I thought, looks good just different.Political Correctness'.........defined
Definitely not done yet. I busted a center drill on one of the holes and called it an evening. Ill have to mill it out with 1/2" end mill.
These are for my CRS project, but another swirled set is for someone else's project and those will be true spiral machining on the outside. He commented something about vertigo hehe.Don't take experimental gene therapies from known eugenicists. -
Ah, ok.Political Correctness'.........defined
The XS-CRS plates breath.....
Do you guys normally drill for the major diameter of the 8-32 screw or the shaft diameter of the hurricane nut insert?
The stud of the nut minus the barbs and the best way to install them is to draw them in with a screw.
The plate looks good, beefy too. I thought you were making a cup type plate at first, but see I was mistaken.Political Correctness'.........defined
Cup type doesn't allow much tap depth nor sidewall for the Neutrik. I don't even need a gasket, just PTFE grease or a touch of RTV if that on sidewall.
Also this design allows up to 3 sets of binding posts if so desired.Don't take experimental gene therapies from known eugenicists. -
Looks like Im going to make a couple sets for monitors without the Neutriks. PM if interested and Ill get extra material.
Now that I've installed a set, Im going to rotate the flange bolts 45* so fresh MDF is drilled into.Don't take experimental gene therapies from known eugenicists.
