Anthem MCA A20 or Parasound 1500a
rburgess714
in Electronics
I have found an anthem mca 20 and parasound 1500a on the used market. The anthem is over 300 dollars more but newer. I will be using a yamaha aventage 1060 as pre. I know there is a lot of love for parasound on this site but the anthem is newer. What are your thoughts? Note due to my console the units depth needs to be no more than 17". Budget is around $650.
Thanks,
RB
Thanks,
RB
Living Room
Parasound HINT 6, Yamaha Aventage RX-A 1060, Oppo 103D, Cambridge Audio Azur 851N, KLH Model 5s, Polk CSi A6, Samsung 65" LED
Office
Yamaha A-S501, Auralic Aries Mini, LSiM 703s
Douglas Connection ICs and Cables
Office
My HCA-1500A is now 14yrs old and working great. It does require plenty of air space or IT WILL shut down on you. Minimum of 9" above clearance. I use a 4 fan cooler on top of mine, drawing air thru the bottom of the amp and exhausting out of the top; and it barely gets warm now.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
I hear that parasound runs hot but mine doesnt. I ran polk sda 1a with it in a two car garage, now media room, and it got warm but didn't cut off. I have read much about this amp always running hot real easily but I've also read that some of them dont... so weird.
The 1205 is another story, it gets hot... hahaHome theater:
43” Westinghouse Displayer
Marantz UD-7007 Player
Emotiva MC-700 Processor
Adcom GFA-5006 Amplifier
Parasound Zamp Amplifier
Ethereal ESO-1 Power Conditioner
Klipsch RC-10 Center
Klipsch R34c Fronts
Klipsch RB-41 Surrounds
Polk audio PSW-505
Stereo:
Polk audio RTA-12c’s fully upgraded crossovers
DIY 12tc braided speaker cables
Denon DVD-5910ci Spinner
Parasound P6 Preamplifer
Parasound HCA -1500a Amplifier -
I'm running all anthem....MCA50, MCA30 , MCA20, and a PVA2 replaced my Adcom 5800's, and 555's and could not be happier.
Ok own both a Parasound 1500A and an Anthem 225 integrated. Both are good amps, with the Parasound a bit on the warmer side. I prefer the Anthem overall, but you can't go wrong with eitherSince we don’t know where we are going we have to stick together in case someone gets there….Ken Kesey
– Kevin Alfred Strom
The creatures outside looked from pig to man, and from man to pig, and from pig to man again; but already it was impossible to say which was which.”……George Orwell-Animal Farm.
