Anyone doing ON wall speakers?
gwh
gwh Posts: 1,451
I'm not ready to retire to a soudbar anytime soon but I have an itch to modernize the look of the front end a bit. Anything good out there?
G
HT:
Martin Logan Motion 40
Martin Logan Motion 50XT
Emotiva Airmotiv E2
SVS SB16 Ultra
Def Tech Reference Sub
Yamaha RX-A3070
Signal Cable speaker wires & interconnects.
    nooshinjohn Posts: 25,928
    Sunfire cinema ribbon trio are amazing. I can get new in box for you for about a grand
  • Erik Tracy
    Erik Tracy Posts: 4,673
    Yes. I'm doing "on wall" cuz of room layout constraints.
    I'd rather do on wall than in wall as I can dabble in different speakers.
    Started with RTi4 and CSi3 and a wimpy PSW303 sub
    Dabbled with LSi7s too:
    Had RTiA3s for quite a while (and got a 'real' sub - Epik Valor 15" sealed):
    Currently using B&W CDM1NT for fronts, CDMC-SE center, still got that awesome Epik:
  • cfrizz
    cfrizz Posts: 13,415
    Cool set up Erik! What do you have in back?
  • mdaudioguy
    mdaudioguy Posts: 5,165
    I'd be interested in flatter on-wall, if there is such a thing.
  • mdaudioguy
    Erik, you've spent a lot of time changing out speakers!
    txcoastal1 Posts: 13,513
    Vienna Acoustics Waltz Grand
    tonyb Posts: 33,072
    What's the budget ? Otherwise this will be all over the map.
  • gwh
    gwh Posts: 1,451
    Dang I forgot about those Sunfire on walls!
    Will need to locate a local dealer to get a listen.
    B stock & used prices look doable.
    Glad I did not give those Epik Empires away I may soon have floor space up front where they belong.
    Much thanks for the replies!
    HT:
    Emotiva Airmotiv E2
    SVS SB16 Ultra
    Yamaha RX-A3070
  • Erik Tracy
    cfrizz wrote: »
    Thanks - it does the job.
    I'm still using RTi4s in back from my first go-round...they do surround duty just fine, and match well with the B&Ws.
  • mdaudioguy
    Although not as slim as some of the above options, Polk's new Signature S35 is an interesting possibility.
    Wall Mountable Left or Right Front Speaker
    Use two (left and right channels) or three to create an optimal, timbre match front (left, right and center) acoustic array. Featuring built-in four-way keyhole slots for easy mounting.
    https://www.polkaudio.com/products/s35
  • gwh
    gwh Posts: 1,451
    Dskip send me some more info on those Totems
    when you get time no hurry.... I just blew my speaker funds on a used camper :(
    HT:
    Emotiva Airmotiv E2
    SVS SB16 Ultra
    Yamaha RX-A3070
