Replacement PSW-120 (8") driver
gp4jesus
Blown. Wide open to the aftermarket
Thanks, Tony
Thanks, Tony
*all connected w/Premiere ICs
Pretty sure, but now wrong, I read from some parts diagrams, this is the same woofer originally used in the Lsi15's Side mounted lower woofer. I will research it more, but if so, there should be dozen's of those available at good prices, as many were replaced with another Polk woofer.
Edit, sorry that was the PSW 250, and Lsi15 that use the same exact woofer, not your sub.
