Dreadnought Cases...........
Ok here we go..
Easy enough as always, the cases are ready to go, just need boxed up..
Cases are $100 shipped just as in the past...
Please when sending PayPal Payment put in the notes what you are buying, it will make this easier with the ring thread as well..
Polk 1.2tl's Fully modded with dreadnought
Rogue Atlas Magnum
Rogue Magnum 66
North Star Intenso Dac
Marantz UD 7007
Pangea PC
Wireworld Equinox 7 interconnects
Wireworld Equinox 7 Speaker Cables and Jumpers
Home theater
Marantz SR 5009 Sunfire Signature 425x5-B&W Cdm1nt Cdm Center Channel
Backups Polk Monitor 5 peerless,2.3tl,SRS2 pin/blade,Polk Crs+ pin/blade with stands.McCormack Dna 0.5 Deluxe,Dared Sl 2000A,Dayens Ampino
1000VA Dreadnought
Dared SL-2000a (Siemens & Halske TM 12AT7WA's, Brimar 5Z4G)
Jolida JD-100a (Sylvania BP TM Gold Brand 5751's), NAD C275BEE, Blue Jeans
RTiA3, Onkyo TX-SR605
Thanks for any feed back.
Pass Aleph 30 | EE Avant Pre | EE Mini Max Plus DAC | MIT Shotgun S3 | MIT Z P/C's | updated SDA 1C| SQ Box Touch/Welbourne Labs P/S- Tubes add soul!
PM me with the payment info.
What about the rings?
http://forum.polkaudio.com/discussion/175963/driver-speaker-rings-for-your-vintage-polk-sdas-monitors#latest
Keep up
Adcom - Carver - McIntosh amps
HT = Polk RTi A9s, CSi-A6, RT-65 -RTi-A3's - Marantz SR5012 - XPA3 - Epson 5040UB
You might as well go Neutrik, everyone else has.
Working with the Neutrik is a treat.
Bonus: You get bragging rights because your SDA cables will be directional.
SDA 2BTL * Musical Fidelity A5cr amp * Marantz DV-9500 * Modded Adcom GDA-600 DAC * Rythmik F8
Micro Seiki DQ-50 * A hodgepodge of cabling * Belkin PF60
My thinking being that if I moved to a different set of SDAs down the road, I'd be able to sell my current ones with a working interconnect for the new person while keeping the Dreadnought for my next pair. (Additionally, if you're a glutton for punishment, you can A/B with/without the Dreadnought to hear its effects. I don't have the time for such exercises.)
Good idea, I was thinking that too after I pondered it a bit. That way when I do modify or replace my terminal cups I'm already 1/2 way there with Neutriks on the tranny end.
https://www.amazon.com/Neutrik-NL2FX-2-Pole-speakON-Connector/dp/B00OVAXIBS/ref=sr_1_5?ie=UTF8&qid=1485441239&sr=8-5&keywords=neutrik
Don't have info to use PayPal for payment ie email address.
(On Driver/Speaker rings, request one set SDA 1C's $70.64 with tweeter brackets $20)
I think those would work on the cable. They do have the higher amperage rating 40A continuous/50A music signal rating you'll want. I used 4-pole Neutrik (NLT4FX-BAG on the cables, NL4MP-UC on the transformer case). I liked the metal casing on the NLT4FX-BAG over the plastic on others.
A consideration is the fact that the NLT4FX-BAG has solder cups only (it was modestly challenging to solder) rather than the "solderable" connections with screw terminals in the ones you linked. I believe solder is preferred for higher current applications; frankly I have no idea what kind of current goes thru these SDA cables.
You want the "D" size chassis mounts to fit Larry's chassis (oh that sounds so wrong), and you'll want the ones with higher amperage rating as well (The NL4MP-UC fits this bill). I also bought Neutrik's SCDP gaskets.
Hopefully Jesse comes by to concur with what I've said/suggested here. I followed his lead in constructing my cables. (With considerably less expensive cable
This isn't the only solution, but it's what I used:
My cable connectors
My Chassis connectors
My Gaskets
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404
Thanks for the part numbers and explanation.
Someone really should write up a comprehensive DIY with part numbers, etc. had no idea there are so many choices.
I'm not sure if it is or not, but if it helps, just do it right the first time.
That's why I didn't want to spend the extra $20, but I can do $5......lol
Bedroom consist of NHT model 2 powered by Parasound hca1200ii coming from my computer.
Stuff laying around. Too much to list but don't want to sell either.
Dreadnought for SDA speakers.
Village Idiot of Club Polk
Saying that it's "too hard" to pursue your dreams is no different than admitting to yourself that you are too lazy to achieve them.
“If it moves, tax it. If it keeps moving, regulate it. And if it stops moving, subsidize it.”
CSi5, FXi5, Rythmik D15SE sub, Pro-Ject Xpression III/Ortofon MC-3 Turbo. Pro-Ject Speed Box. Pro-Ject Tube Box II
