Cary SLP-03
2
  • acmf74
    acmf74 Posts: 937
    Is there a model of Mullard or RCA I should look at? These is new to me
  • mikeyb128
    mikeyb128 Posts: 2,885
    acmf74 wrote: »
    How much do you want to spend? What other gear do you have?
    2 channel:
    Theater:
  • acmf74
    acmf74 Posts: 937
    Jolida CDP w/Psvane tubes
    Cary SLP-03 Pre
    Mark Levinson no27 amp
    Polk Lsi 15s
    Full MIT loom
    Price range I would like to gauge from the consensus here.
  • Joey_V
    Joey_V Posts: 8,603
    edited January 2017
    Why don't you first listen to it before spending more on tubes?
    My recs are I enjoy the rca nos that I have and I switch between a newer tung sol as well.
    Currently popes dominate my 05, though I stuck a couple EH just to see how I like it.
  • acmf74
    acmf74 Posts: 937
    Joey_V wrote: »
    Absolutely. The tubes are brand new and need to burn in.
    I'm just curious on which tubes are recommended. Just in case I find a great deal.
  • acmf74
    acmf74 Posts: 937
    Is there a preference to NOS vs new tubes? ie Mullard/RCA 12au7?
  • mikeyb128
    acmf74 wrote: »
    I quite enjoy anything RCA, I have all varieties, JRC 5814A, also in triple micas, my favorite is long black plates. I would say grab some 5814 commands, and enjoy them, they are cheap, quiet, and sound huge!
    I have lots of European tubes from valvo, Mullard, amperex, brimar, and I always come back to US production tubes, they are just so good for the money.
    2 channel:
    Theater:
  • acmf74
    acmf74 Posts: 937
    Is there a difference in the 12au7 & the 12au7a?
  • mikeyb128
    The "A" suffix in 7 and 9 pin mini types indicates controlled heater warm up time. Controlled heater warm up time was introduced to permit long series heater strings of disparate types in TV sets. The TV set manufacturers did not want to pay for power trafo heater windings. The bottles lacking the "A" suffix are earlier production. The machinery used had less wear and tear on it, in that time frame.
    Other than the heaters, there are ZERO electrical specification differences between specimens of a type with and without the "A" suffix.
    I find the "A" to be a little quieter. I use them in my Cary.
    How's this 03 working out for you?
    2 channel:
    Theater:
    heiney9 Posts: 25,487
    Just to whet your appetite.
    I am getting ready to post some of the rarer holy grain 12AU7/ECC82 type tubes shortly. My collection has become too large for some tube types and I need to thin the herd.
    Just an fyi to keep in the back of your mind if interested.
  • kevhed72
    kevhed72 Posts: 5,153
    heiney9 wrote: »
    Im game....I have been trolling NOS tube store lately but can wait....
  • acmf74
    acmf74 Posts: 937
    mikeyb128 wrote: »
    Thanks for the info!
    The 03 opened up very nicely. I hearing new nuances in my music and sounds much more "natural'. I think I will keep it for sometime and enjoy some tube rolling."
  • Upstatemax
    Upstatemax Posts: 2,775
    Joey_V wrote: »
    I have some thoughts about the future pre but honestly I have nearly zero itch.
    Well, you went from zero to a hundred pretty quick!
    Haha.
  • vmaxer
    vmaxer Posts: 5,120
    heiney9 wrote: »
    @heiney9 I am very interested. Let me know please.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • acmf74
    acmf74 Posts: 937
    Holy cow. The RCA blackplates opened up the pre sooooo niceley. Thanks for the recommendation!
  • mikeyb128
    acmf74 wrote: »
    Which ones did you pick up? I find all rca to have a fantastic soundstage.
    2 channel:
    Theater:
    Cool gents, I have some RCA 5751's blackplates in my pre and they sound pretty frickin' good.
  • acmf74
    acmf74 Posts: 937
    Not sure but these are RCA made for CONN.
  • mikeyb128
    Long black plates with angled D getter. I have loads of these. My favorite right now. The earlier the better. I have some 1951 with angled square getter, they are super sweet. And thy do sound slightly different.
    2 channel:
    Theater:
    RCA's are always solid performers. Earlier tubes in general are preferred from all manufacturers, they can have some qualities that are hard to duplicate even from the same manufacturer years later.
    I really encourage getting your ears on as many old stock tubes as possible (as much as one can afford) because you ain't heard nothing yet!!! :D
  • @heiney9
    Did RCA tubes ever have a gray plate? And is there a sonic difference in the black vs gray plate? Asking because I have a lead on 4 6350 gray plates, per the sellers description. And if it's not to much trouble, does the Getter type matter?
    TIA
  • acmf74
    acmf74 Posts: 937
    I believe the gray plates are called "Clear Tops".
    They made gray plate tubes, long plate, short plate, top getter, side getter. The getter type doesn't directly impact the sound, but it can date most tubes in general and can be used as an identifier.
    I am not that familiar with the sound signature of the 6350's so I can't say which is better black or gray plates. Generally for American tubes, the black plates are early tubes and gray plates later tubes. That's in general as some makes made black plates later than others.
    You'll just have to roll some tubes to see which you like best in your rig.
    edited February 2017
    acmf74 wrote: »
    RCA made a side getter 12AU7 that has gray plates, but there are others, long plate and short plate that are also gray.
    Post edited by heiney9 on
  • WagnerRC
    WagnerRC Posts: 2,209
    Should all tubes have some type of plate. I received these and not sure it the plates came off. Thanks
    No, different tube designations can have different plate construction, even same designations can have different plate construction.
    I don't understand the question:
    What came off? Where?
  • WagnerRC
    Found this in one empty box
  • mikeyb128
    ^^ I think those are for transportation pruposes to
    Protect pins.
    2 channel:
    Theater:
    Not sure those came from the factory, but they are pin protectors. Keeps them from getting bent and to some degree keeps oxidation off the pins.
  • WagnerRC
    Thats what it looks like. Thanks
