Speaker wire
tonyb
Looking for a set of speaker wire can be anywhere from 4 ft to 8 ft with bare ends. Doesn't have to be top quality either, just decent sounding. What do you guys got in your closet ?
I have a couple pairs of 12ga Furez that Doug sells. It is like $.88' I think. You can have it for the cost of postage. The lengths are about 56".Patriotism is the last refuge of a scoundrel…….Samuel Johnson
– Kevin Alfred Strom -
motorhead43026 wrote: »I have a couple pairs of 12ga Furez that Doug sells. It is like $.88' I think. You can have it for the cost of postage. The lengths are about 56".motorhead43026 wrote: »I have a couple pairs of 12ga Furez that Doug sells. It is like $.88' I think. You can have it for the cost of postage. The lengths are about 56".
Thanks man, but I have something similar in there now in that second system.HT SYSTEM-
lsi 9's -
I have some frayed and oxidized lamp cords that I spiced together and then baked in my little sister's Easy Bake Oven I can send you if the wire the other guys offered to basically give you for free isn't good enough for you.
You will still have to pay for shipping though.
2 channel:
Theater:
Focal Aria 926,905,CC900, SVS PB ultra x2. Pioneer Elite SC85, Oppo BDP93, Panamax M5400PM, Minix neox6, Nordost Blue heaven LS power cables. -
I've still got 2 runs 8 foot of unterminated Canare 4S11, one is in use for my center but I'm planning on putting a Transparent Musicwave cable there since they got displaced by the AVT3s.
I might be game when you want to get rid of hit me up.
I think I have some Mapleshade Double Helix v2 with Plus that you can have for a 12 pack of good beer, or $20. These were my first speaker wire upgrade from Home Depot 12 gauge.
http://shop.mapleshadestore.com/Double-Helix-V2-Speaker-Cables-with-PLUS-Upgrade/productinfo/DHELIX2-PL/Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
If Tony passes let me know. Thanks. -
That is more of a special in recognition of his fictional essays.
No worries. Just looking for a good 50th B-day present from my daughter. I could have her write you a nice essay.
