Epik subwoofers no plate amps pick up only
gwh
Two Epik Empire Subwoofers no plate amps, cat scratch fever on the grills, marks on the cabs, SVS isolation feet. One plate amp opening trimmed to accept aftermarket plate amp.
$150 each cash pick up lawton oklahoma.
Also one SVS CS 16-46 original driver dinged grill missing SVS sticker $75 pick up only.
Trade all three for a Defenitive supercube one if you are low on cash.
h.
h.
HT:
Martin Logan Motion 40
Martin Logan Motion 50XT
Emotiva Airmotiv E2
SVS SB16 Ultra
Def Tech Reference Sub
Yamaha RX-A3070
Signal Cable speaker wires & interconnects.
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
Wow. Wish you were closer"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
I agree Enders, these are excellent subs and can be run again solidly with a pro audio amp, wish I was closer too.
My type of subs here. What a nice chance for someone to get big clean bass for cheap. $200 pro amp, $500 total! No brainier here for those in OK.2.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Sub 1 - Mirage Omni S8 | Sub 2 - Mirage Omni S8
I'll even throw in this taxidermy bass..... killer bass and bass for your mancave.
HT:
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
Signal Cable speaker wires & interconnects. -
Might do some trading and drive a couple hours.
Looking for high res security camera package, 65 inch 4k, Def Tech 1 or ref, Anthem pre.
I also have a pair of DT 7004's I'm not using.HT:
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
I feel embarrassed mentioning this. I too have an Epic Empire. I bought one the first week they were available. It is still in it's delivery box in my dining room, never unpacked it. I've been waiting for a chance to set up a HT, still need other pieces. Work and caring for a parent are the priorities in my life. I've read as long as you don't crank the volume on the Empire their amps will not fail as much? Does anyone have any thoughts on this? I know they are out of business, how high is the amp failure rate? Good to know other amps can be made to work if needed.
You need to make a trip to the city some time...... I never go down that way anymore. Would totally take a sub off your hands. Have a buttkicker amp coming that would power one of those without a problem that I got cheap.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
Man totally have an amp for this now too.Main Surround -
Last time I looked they were still out in the garage.
HT:
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
