Preferable Sonos connection
I recently picked up a Sonos Connect and was wondering if I should use the optical or coaxial output ? Or doesn't it really matter ? I'm presently using a Parasound Halo Integrated and a video coaxial interconnect because that's all I had around the house.
    edited January 2017
    I can only speak from personal experience, but...I'd use a digital coax cable, and one of decent quality not an old video cable.
    MIT makes a decent digital coax for cheap too....as well as many others.
  • Ricardo
    Ricardo Posts: 10,634
    MIT and cheap in the same sentence. Things must have changed a lot in the last 5 years :D
    SOPA
    Their clearance site used to have them under 100 bucks, don't know if they still maintain that clearance site though.
    I'm pretty sure Skip may have a Wireworld digital coax hanging around too. I'd try and find a digital cable with not a lot of glare to it for using with a Sonos, as that top end glare with the wrong cables can be a tad irritating.
    Look on HI-FI SHARK, US Audio Mart, Audiogon, here...that Audio nerd dude doesn't have near what the old clearance site had.
  • RamZet
    RamZet Posts: 792
    tonyb wrote: »
    I agree and this is how I have mine.
    B&W CM9Classé Sigma
