New receiver necessary upgrade?
Hey all, I'm using a Denon AVR1713 (5.1) currently with Polk monitor 60's front, Polk csi A6 center and two Polk tl2's surround.. also SVS pb12 sub. I have a little to spend on a new receiver, (1713 is not 4K pass thru but I've worked around that).
I'm looking at the Anthem mrx 520 (a little over my budget) or whatever suggestions I can get for around a grand. Question is will it be worth it? Will there be a significant improvement in the quality of the sound and clarity? I really don't want to spend the money if it's not going to improve my overall experience. Any advice or suggestions? Thanks, John.
  • rpf65
    rpf65 Posts: 2,127
    If I were going to upgrade, and budget was around 1k, I would probably look at Marantz, Yamaha Aventage, or Pioneer Elite. If staying at 5.1, I think you'll get better bang for your buck.
    Seems to me what your looking for is a newer 4K compatable AVR. Will allow you to play and stream the newer formats. Won't limit your choices of movies, even if you decide not to add speakers.
  • mrloren
    mrloren Posts: 2,474
    You could always see if something at A4L works for you http://www.accessories4less.com/make-a-store/category/avreceiver/home-audio/receivers-amps/home-theater-receivers/1.html
    I just got a Marantz SR5010 from there last month. A co-worker just picked up a new Denon form them no problems.
