SDA2A and Carver M1.0T Bridged
sevendogs
sevendogs Posts: 3
edited January 2017 in Vintage Speakers
Hello everyone, I have been running a pair of Polk SDA2A's and a single Carver M1.0t amp for 28+ years now and I love the set up. A buddy of mine sold me his M1.0T for $100, which of course I could not pass up. Both units have the bridging switch. Can I bridge these amps and run them in mono mode with the SDA2As? I have been searching on the Internet for someone else with a set up like this to see if this would work but haven't found any examples. I know how to hook up the cables, just not sure the fact my Polks are 4 ohm and the amps are rated at 8 ohms when bridged will cause an issue. Rather not smoke check my components...
  • Schurkey
    Schurkey Posts: 2,122
    You cannot use bridged amps with SDA speakers unless the SDAs can use the isolation transformer. Far as I know, the 2As are not compatible with the isolation transformer, so "no" you can't use the two bridged amps and still have the SDA cable connected.
  • Thank you for your response - I can lose the SDA cable, that's not a problem. I was more concerned with the fact the Carvers are not rated for 4 ohms bridged so didn't know if hooking them to the Polks while bridged would cause an issue.
  • Schurkey
    I suppose that's likely to cause problems, too.
    One wonders if the "Mark II opt 002" mod would improve the low-impedance drive capacity of the 1.0T.
  • Well, mechanically it works, no sparks, smoke ( :p ) at low volumes but without the SDA cable they sound very different. Well, not sure how to proceed. Because of their impedance, I am hesitant to crank them, not that I abuse them in any way, but I do like to feel the music. If they dip below 4 ohms not sure how the Carver's will take it. I have seen those mods, will look into it, thanks.
  • hochpt21
    hochpt21 Posts: 5,423
    The SDA cable is what makes the speakers what they are. (They are who we thought they were! RIP Denny Green)
    I've never tried what you are saying, but most bridged amps don't like 4ohm loads from what I understand.
  • Schurkey
    edited January 2017
    sevendogs wrote: »
    Except for the soundstage collapsing to "ordinary" stereo, and--maybe--a bit less bass, the speakers shouldn't sound any different.
    First Guess: Something is wrong, either in the speakers or in the electronics driving them. Can you confirm the change using one stereo amp, with and without the SDA interconnect?
  • Schurkey
    edited January 2017
    pitdogg2 Posts: 27,055
    Can't see this being a good idea. Sda2a are 4ohm and dip lower, your noise floor just rose up. These amps will get very warm when driven in this configuration. Definitely do not plug in that SDA cable while bridged.
    My.02
    F1nut Posts: 51,783
    edited January 2017
    I'd lose the amps, you'd be surprised at how much better other amps sound in comparison.
    That said, you should never use bridged amps with less than 8 ohm nominal loads and as mentioned bridged amps have a much higher noise floor.
  • Schurkey
    edited January 2017
    Depends on the bridged amps being used. Aragon Palladiums and Iridiums are bridged; but FTC-rated for 4-ohm loads, and advertised for lower impedance still. (~1000 watts into 2 ohms)
    I'm thinking the Adcom GFA555 were also rated for 4-ohm use when bridged.
    I'm sure there are other examples.
    Note that having a bridged amp that will drive low-impedance speakers does not change the fact that bridged amps don't play well with SDAs unless there's an isolation transformer in the SDA interconnect.
