McCormack DNA-1, common ground?
Looking at acquiring this amplifier, but before I make the trek, can anyone confirm it is a common ground amplifier, and able to drive a pair of SDA SRS's?
Thanks!
  • Confirmed strapped negative terminals using my good 'ole fluke multi meter,
  • MrBuhl
    MrBuhl Posts: 2,419
    Your SRS should love that DNA. I have been incredibly pleased with the SDA / McCormack match!
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
  • Just finished hooking it up. Warming up as we speak.
    Since you owned one: does the "protection" LED light up for a short time after powering up the amp?
    Mine was on and I had a moment of panic thinking that the SDA is putting the amplifier under duress. The LED did turn off after a few seconds and the amplifier is, well... amplifying as it should.
    Just wanted to confirm.
    Thanks!
  • MrBuhl
    MrBuhl Posts: 2,419
    edited December 2016
    Yes, protect light is related to soft starts / warming up. Comes on initially then should pop off shortly after warm up! No worries at all!
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
  • vmaxer
    vmaxer Posts: 5,120
    Great amp, enjoy.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • It is indeed a glorious combination.
    Thank you for your input.
  • jdjohn
    jdjohn Posts: 3,322
    Good investment. That amp will make anything sound better. I've used a DNA 125 for SDAs, Infinity RSIIIAs, and currently driving Maggie SMGs.
    tonyb Posts: 33,065
    Nice pickup bro, one of my personal favorite SS amp brands. I've pushed a few around here, at the very least people realize all SS amps do NOT sound the same.
  • jdjohn
    jdjohn Posts: 3,322
    Yes, Tony is the McCormack enabler ;) I first tried Adcom, B&K, Carver, PS Audio, but once I heard the McCormack, it was all over.
  • BlueBirdMusic
    BlueBirdMusic Posts: 2,745
    edited January 2017
    What years were the McCormack DNA-1 amps manufactured? Thanks.
    Harry / Marietta GA
  • jdjohn
    jdjohn Posts: 3,322
    Good question. The schematic for my DNA-125 is dated June 2005.
  • Thank you! I have been looking for either a DNA-0.5 or DNA-1 to come up for sale locally for some time now. Got lucky with this one, I must say.
    Its been fantastic so far, however, it has also showcasing my SDA SRS signs of aging.
    Time to update a few drivers and x-overs I reckon.
  • To add to my last post: I wonder if the SDA SRS's are worth pursuing.
    One of the tweeter arrays distorts ever so slightly.
    I reckon both tweeter arrays should be replaced with RDO194, and the x-overs should receive all new capacitors. No small $$ feat when eight tweeters are required.
    For the first time since my climb up the Polk SDA ladder, starting with SDA2B's, which i loved, then a wonderful pair of pin/blade SRS2's which I I was enamored by, to the SDA SRS which are leaving me wanting and wondering if I should look elsewhere for sonic nirvana.
  • Before I have $2500 in these speakers, that is. As now I can probably move them at no or minimal loss.
