Oppo UDP-203 4K UHD Blueray player
13»
    As you can see the Onkyo and Integra units are one and the same. They just put a couple of features on one that they did not on the other is all.
  • afterburnt
    afterburnt Posts: 7,892
    any idea if it still does HDCD?
  • Emlyn
    Emlyn Posts: 4,623
    The manual does not list HDCD decoding, but I have not personally confirmed if it does or does not. Possible workaround if it doesn't decode is to run coaxial out to a receiver if it decodes HDCD. My hunch is if the manual no longer lists it and they switched to a new AKM DAC the HDCD decoding is no longer built in. If course it will still play the CD fine either way.
  • BlueFox
    BlueFox Posts: 15,251
  • polrbehr
    polrbehr Posts: 2,842
    BlueFox wrote: »
    Agreed, almost makes me want to go out and buy a 4K television... but I don't like
    that the apps are missing, I love using my 103 to stream Netflix.
  • BlueFox
    You could use both. New TVs have multiple HDMI inputs, and the 203 has an HDMI Input. You deserve it. Go buy the TV and 203. :)
    gudnoyez Posts: 8,156
    edited December 2016
    I'm waiting patiently for the 205 and Sonys offering both due out this spring just picked up my 3rd UHD disc today The Magnificent 7. I can watch the blu Ray but not the UHD until spring. Glad your enjoying the 4k goodness.
  • BlueFox
    Encountered my first firmware bug last night. While watching Lucy in 4K the dialogue would skip and/or stutter. On another forum it was mentioned Oppo is aware of it, and is working on a patch. As a bug, it is mostly a small annoyance, but still it will be nice to get the fix.
  • RamZet
    RamZet Posts: 792
    Nightfall wrote: »
    They're using an AKM DAC this time around, never heard of them.
    AKM is used in the Logitech Transporter and was used in B&K gear. Bryston uses two of them in their DAC.
    It is hands down one of the best sounding DACs in my book.
    B&W CM9Classé Sigma
  • BlueFox
    Another firmware bug popped up today. I am watching a Netflix DVD rental, H e l l or High Water, and a message pops up saying this DVD does not meet something, and the audio is being disabled. LOL. I press OK, and it continues to work, but then the message reappears. Power cycle it, and now it is fine.
    Incidentally, this regular DVD looks fantastic, and the movie is interesting also.
