Let's see your POLK set up!
jbarlow80, you got it.
Just one tip, a big tip at that. Get your AVR off that stand on top of the sub man, you're going to rattle the solder joints loose in it otherwise.Political Correctness'.........defined
President of Club Polk -
Looks like an Onkyo 705 with a notebook cooler on top. The sub10 should be plenty, I would just use the psw as an avr stand.Oh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant
I built a stand around the sub and put the receiver on it it's an onkyo 707 and I cut racquet balls in half and set the receiver on those for an absorber that notebook cooler keeps the the receiver pretty cool
Yes, we see that, but it doesn't change the fact that your AVR should not be where it is.
As your AVR has plenty of open space around it right now there's no reason to put that cooler on it. The components inside designed to work at certain temperatures, if not allowed to reach those they won't perform their best.Political Correctness'.........defined
@jbarlow80
Welcome to the forum
While I may not always agree with @F1nut,he KNOWS what he is talking about.
Yes,yes to F1nut you listen hee hee
@jbarlow80
Yes welcome. And I think you have a pretty sweet setup! I am jealous. And I have to admit i have never actually had the pleasure of hearing a RT5000 setup, everything I have read indicates that those subs should destroy the polk psw and klipsch. Do they really make it sound better? Honest question.
And yet, the nut knows ;-)Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
The amps are humming need to get them repaired so I have stand alone subs right now I found this setup at the thrift store a few months back for 75 bucks
Those amps on the 3000p's are pretty old and might need some repair....but, it can also be a ground loop issue or cable issue. The cheapest way to determine is to lift the ground on the power cords for those amps. The easiest way to do that is to go buy a couple 2 dollar cheater plugs at any hardware store or Home Depot. A cheater plug attaches to the end of the power cord and turns it from a 3 prong plug to a 2 prong plug.
Having too many grounded plugs on one wall outlet can result in some ground loop issues. You can also try plugging them into a different wall outlet than the rest of the system is on. I've had those exact speakers and was always fighting hum issues.HT SYSTEM-
lsi 9's -
2 channel:
Theater:
Focal Aria 926,905,CC900, SVS PB ultra x2. Pioneer Elite SC85, Oppo BDP93, Panamax M5400PM, Minix neox6, Nordost Blue heaven LS power cables. -
Thanks again for the comments/advice of my system currently working on moving the avr above the TV eventually just looking for the right size shelf to do so and mikeyb128 very nice system you have there.
2 Channel Focal Kanta 3 I Modwright SWL9.0 Anniversary Pre I Modwright PH9.0X I Modwright KWA-150SE I VPI Prime Signature w/ Soundsmith Zephyr MIMC I Lumin U2 Mini I North Star Designs Intenso DAC I Audience OHNO ICs/Audience Furutech FP-S55N and FP-S032N Power Cables/Acoustic Zen Satori I Isotek Sirius -
Polk Fronts: RTi A7's
Polk Center: CSi A6
Polk Surrounds: FXi A6's
Polk Rear Surround: RTi4
Sub: HSU VTF-3 (MK1)
AVR: Yamaha RX-A2010
B&K Reference 200.7
TV: Sharp LC-70LE847U
Oppo BDP-103 -
Livingroom LSi7 + LSiC setup.
SO... Who won the prizes?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
I think Lightmans in your face introduction blew it for all of us (sigh) thanks a bunch Russ
My bad....sorry folks..... -
Daughters' #1 bedroom
Daughter #2 bedroom
Post edited by recoveryone onFamily Room HT 7.2/i]:Vizio Oled55h1 Pioneer Elite SC-LX502 Pioneer Elite BDP 85FD Eversolo DMP A6 Panamax M5300-EXSpeakers Fronts Fluance XF8L Center Polk Audio S35 Side Surrounds Fluance bipolar Rear Surrounds FluanceXF8 Bookshelf Subs SVS PB4000 x2 Living room 2ch: Crown Xli 1500 amp x2, Teac EQ MKII FX Audio X6 Mk II DAC Squeezebox Touch Polk Audio R700 Speakers Panamax M5100-EXOffice media room:Vizio M50Q6 50" Pioneer Elite VSX LX301 Eversolo DMP-A6 Polkaudio R600 Towers Polkaudio Center R350 Panamax M4300 Monoprice 12" subMaster bedroom:Vizio M55Q7 Pioneer Elite VSX LX302 Pioneer Elite BDP 85FD Squeezebox Touch Fluance Signature Bookshelf fronts, Rears Fluance Signature Bipolar Polk Audio CS10 center Monoprice 12" sub Panamax M5300-EX -
Daughter #3
Master Bedroom
^Lot of squeezebox touch love I see. If those ever need to get sold, let me know hehehe"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
I have a total of 6 now, one for each room of the house. Can't wait for all of them to leave so I can create my own listening room
Is that hot rollers in between the Polks?
yup, my oldest daughters' roomFamily Room HT 7.2/i]:Vizio Oled55h1 Pioneer Elite SC-LX502 Pioneer Elite BDP 85FD Eversolo DMP A6 Panamax M5300-EXSpeakers Fronts Fluance XF8L Center Polk Audio S35 Side Surrounds Fluance bipolar Rear Surrounds FluanceXF8 Bookshelf Subs SVS PB4000 x2 Living room 2ch: Crown Xli 1500 amp x2, Teac EQ MKII FX Audio X6 Mk II DAC Squeezebox Touch Polk Audio R700 Speakers Panamax M5100-EXOffice media room:Vizio M50Q6 50" Pioneer Elite VSX LX301 Eversolo DMP-A6 Polkaudio R600 Towers Polkaudio Center R350 Panamax M4300 Monoprice 12" subMaster bedroom:Vizio M55Q7 Pioneer Elite VSX LX302 Pioneer Elite BDP 85FD Squeezebox Touch Fluance Signature Bookshelf fronts, Rears Fluance Signature Bipolar Polk Audio CS10 center Monoprice 12" sub Panamax M5300-EX
Where did the prize patrol go?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
That is some of the coolest stuff I've seen in a long time
Hi All, if you haven't already heard - I've chosen a handful of the best photos our team saw here on the forum. They include @mdaudioguy, @MrBuhl, @mikeyb128, and @badchad ! I've already messaged each of you and will be sending out your Polk prizes next week. If you didn't win this time, don't worry, we'll be running contests in the future! So be sure to stay tuned!
Guess the old school guys get no love... lol
