Let's see your POLK set up!
135
    F1nut Posts: 51,794
    edited December 2016
    jbarlow80, you got it.
    Just one tip, a big tip at that. Get your AVR off that stand on top of the sub man, you're going to rattle the solder joints loose in it otherwise.
  • Looks like an Onkyo 705 with a notebook cooler on top. The sub10 should be plenty, I would just use the psw as an avr stand.
  • I built a stand around the sub and put the receiver on it it's an onkyo 707 and I cut racquet balls in half and set the receiver on those for an absorber that notebook cooler keeps the the receiver pretty cool
    F1nut Posts: 51,794
    Yes, we see that, but it doesn't change the fact that your AVR should not be where it is.
    As your AVR has plenty of open space around it right now there's no reason to put that cooler on it. The components inside designed to work at certain temperatures, if not allowed to reach those they won't perform their best.
  • @jbarlow80
    Welcome to the forum
    While I may not always agree with @F1nut,he KNOWS what he is talking about.
    Yes,yes to F1nut you listen hee hee :D
  • rooftop59
    rooftop59 Posts: 8,121
    @jbarlow80
    Yes welcome. And I think you have a pretty sweet setup! I am jealous. And I have to admit i have never actually had the pleasure of hearing a RT5000 setup, everything I have read indicates that those subs should destroy the polk psw and klipsch. Do they really make it sound better? Honest question.
    And yet, the nut knows ;-)
    Game Room 5.1.4:
    Bedroom 2.1
  • The amps are humming need to get them repaired so I have stand alone subs right now I found this setup at the thrift store a few months back for 75 bucks
    tonyb Posts: 33,072
    Those amps on the 3000p's are pretty old and might need some repair....but, it can also be a ground loop issue or cable issue. The cheapest way to determine is to lift the ground on the power cords for those amps. The easiest way to do that is to go buy a couple 2 dollar cheater plugs at any hardware store or Home Depot. A cheater plug attaches to the end of the power cord and turns it from a 3 prong plug to a 2 prong plug.
    Having too many grounded plugs on one wall outlet can result in some ground loop issues. You can also try plugging them into a different wall outlet than the rest of the system is on. I've had those exact speakers and was always fighting hum issues.
  • Thanks again for the comments/advice of my system currently working on moving the avr above the TV eventually just looking for the right size shelf to do so and mikeyb128 very nice system you have there.
  • stangman67
    stangman67 Posts: 2,329
  • maximillian
    maximillian Posts: 2,149
    Livingroom LSi7 + LSiC setup.
    nooshinjohn Posts: 25,932
    SO... Who won the prizes?
    gudnoyez Posts: 8,166
    I think Lightmans in your face introduction blew it for all of us (sigh) thanks a bunch Russ :|
  • lightman1
    lightman1 Posts: 10,796
    :/:# My bad....sorry folks.....
  • recoveryone
    recoveryone Posts: 929
    Daughters' #1 bedroom
    Daughter #2 bedroom
    Post edited by recoveryone on
    Daughter #3
    Master Bedroom
    EndersShadow Posts: 17,705
    ^Lot of squeezebox touch love I see. If those ever need to get sold, let me know hehehe
    Slacker... >:)
    Daughter #2 bedroom
    Slacker... >:)
  • I have a total of 6 now, one for each room of the house. Can't wait for all of them to leave so I can create my own listening room :wink:
  • maximillian
    Is that hot rollers in between the Polks?
  • yup, my oldest daughters' room
    Where did the prize patrol go?
    txcoastal1 Posts: 13,513
    edited January 2017
    You're the loser....get over it :o:D:D;)
  • That is some of the coolest stuff I've seen in a long time
  • Hi All, if you haven't already heard - I've chosen a handful of the best photos our team saw here on the forum. They include @mdaudioguy, @MrBuhl, @mikeyb128, and @badchad ! I've already messaged each of you and will be sending out your Polk prizes next week. If you didn't win this time, don't worry, we'll be running contests in the future! So be sure to stay tuned!
    Guess the old school guys get no love... lol ;)
