New 2 Channel Setup Cable Suggestions
13
  • kharp1
    kharp1 Posts: 3,453
    I rend to agree with your plan. Get used to your gear first. That way changes you make will be easier recognized. I also agree with the pre-owned route as well. Go through a few different brands and types to gain some first hand experience.
    Welcome to the rabbit hole!
  • Willow
    Willow Posts: 11,246
    Joey_V wrote: »
    sgmsmg wrote: »
    Oh well. I got some good info to work with. I think I am going to get used to my gear for now. I will swap in some locally sourced balanced interconnects to see if there is any noticeable difference. In the meantime I will get rid of my leftover home theater stuff and use those funds to put towards cables in the future.
    Just try not to go crazy on everything like I did.
    Fixed it for you.
  • If Joey is crazy, I want to be Joey. o:)
    Man....how about this, those of you who are cable naysayers.....don't post in a thread about cables. You guys always monkey up these threads and get them closed.
    We have a member who seriously wants to learn about cables and synergy, that's part of audio in case some forgot what we do around here.
  • pkquat
    pkquat Posts: 748
    I'll take the blame. I said things you should not say out loud. "WOW, a good cable thread" (budget cables no less). I was worried about posting that. Its like saying "I'm going to leave work early today", "Be there in 5 min", or "Traffic is looking great for this time of day, we should make great time". :p
    sgmsmg wrote: »
    Post back your thoughts on the balanced cables, or pm me. :) PS welcome to another internet forum cable thread. :/ Most folks on here are insightful, and threads are informative, but certain topics always seam to go downhill.
  • kharp1
    kharp1 Posts: 3,453
    I certainly meant no disrespect to the OP or anyone else. I was poking a bit of fun at the whole market in general as there is often an excess of hyperbole that, at times, borders on the snake oil salesman. I see no reason why some fun can't be had along the way while learning and sharing experiences. It's one of the ways we can make it a less "sterile" enviroment and learn about each others character and personality. I do agree that just because you haven't had the awakening expereince of cabling noticeably changing your system is no reason to flame.
  • Dawgfish
    Dawgfish Posts: 2,554
    I just want to throw in that I've tried several types of speaker cables, interconnects, power cables, digital cables, etc. from the likes of Audioquest, Acoustic Zen, MIT, ZU, etc. and I've had great synergy using Analysis Plus in my systems. Just wanted to throw that out there as another viable option. There are a lot of them out there, it's really just a matter of experimenting and finding what works best to your ears in your budget.
  • sgmsmg
    sgmsmg Posts: 556
    I knew it was all in fun. This is the internet and the forums are supposed to be a fun way to share/learn/entertain.
    There was a delay picking up the XLRs until this weekend but I will follow up with observations.
    One question I have is regarding power protection/filtering and 2 channel setups. Is it a good or bad thing to have everything running through my Panamax 5300-PM. I know these are more for home theater applications but for now it is all I have until I upgrade to something like a PS Audio. I am already using better than stock power cables (Pangea AC-9/AC-14SE).
    Pre: Bryston BR20
    Amp: Buckeye NCx500
    Speakers: Polk L200
    Source: Oppo UDP-205, Bryston BDP-3, Bryston BCD-3, Apple TV, Amazon Fire
    Cables: Wireworld Gold Eclipse 7 Speaker, Wireworld Gold Eclipse 7 XLR, AQ Diamond USB/HDMI
    Power: PS Audio P10 Regenerator, AC12, AC10 and AC5 Cables
    Display: Sony XBR65Z9F
    Pre: Anthem AVM90
    Amps: Buckeye NC502
    Speakers: Polk LSiM 707 (FL/FR), Polk LSiM706 (Center), LSiM 703 (SL/SR/SBL/SBR), Polk 900-LS (Atmos)
    Subwoofers: SVS SB16 x 4
    Source: Oppo UDP-205, Apple TV, Amazon Fire
    Cables: AQ Meteor/Rocket 88, AQ Niagara/Sky
    Power: Torus AVR20, Shunyata Denali, Shunyata Delta, Cullen, PangeaAC9SE Cables
    Display: Sony XBR85Z9G
  • sgmsmg
    sgmsmg Posts: 556
    Dawgfish wrote: »
    Thanks for the feedback. I have read up on Analysis Plus cables and they are on the quickly expanding list of possibilities.
    Pre: Bryston BR20
    Amp: Buckeye NCx500
    Speakers: Polk L200
    Pre: Anthem AVM90
    Amps: Buckeye NC502
    Normally everything but power amps, as some power conditioners can be limiting on current.
  • Analysis plus, for the money are hard to beat.
    – Kevin Alfred Strom
  • sgmsmg
    sgmsmg Posts: 556
    tonyb wrote: »
    That is what my concern was. Should I just make sure I unplug my amp when not in use?
    Pre: Bryston BR20
    Amp: Buckeye NCx500
    Speakers: Polk L200
    Pre: Anthem AVM90
    Amps: Buckeye NC502
  • sgmsmg
    sgmsmg Posts: 556
    There definitely seems to be more deals to be had on these.
    Pre: Bryston BR20
    Amp: Buckeye NCx500
    Speakers: Polk L200
    Pre: Anthem AVM90
    Amps: Buckeye NC502
    Good cables, have the AP crystal ovals on one piece. Non fatiguing high end, nice wide soundstage and midbass, just a tad lacking in lower bass oomph and detail. Least in my system anyway. That's were the AZ cables brought the goods for me. Not exactly cheap either retail, but pretty affordable on the used markets too.
    F1nut Posts: 51,917
    sgmsmg wrote: »
    tonyb wrote: »
    No need unless you're having a T-storm or away for awhile.
    sgmsmg wrote: »
    tonyb wrote: »
    Not really, like F1NUT said, unless your prone to brown outs and lightning strikes in your area, or heading to the Bahamas for a few weeks. Simple small fluctuations in line voltage won't hurt modern equipment.
  • sgmsmg
    sgmsmg Posts: 556
    sgmsmg wrote: »
    tonyb wrote: »
    tonyb wrote: »
    sgmsmg wrote: »
    tonyb wrote: »
    Good to know thanks!!!
    Pre: Bryston BR20
    Amp: Buckeye NCx500
    Speakers: Polk L200
    Pre: Anthem AVM90
    Amps: Buckeye NC502
  • voltz
    voltz Posts: 5,384
    I use the AP black mesh oval 12's with my SDA- CRS+'s and Dave made me a inter-connect cable with the same cable :)
    I'm using Acoustic Zen -Satori's on my 705's.
    F1nut Posts: 51,917
    The advice given with the above exception has been spot on. Most amp manufacturers will tell you to plug straight into the wall. Those that tell you to.....well you likely don't want one of their products.
    F1nut Posts: 51,917
    *not to......
  • gp4jesus
    gp4jesus Posts: 2,019
    tonyb wrote: »
    VERY simple, VERY small fluctuations.
    1.The power company fixed the damaged neutral
    2. I ran a dedicated 20A,
    3. I sent my then (9/2015) new Outlaw prepro to repair
    As of 12/2015 I power all my low-draw gear by an APC H15 plugged into a dedicated 15A. All my amps powered by two dedicated 20A.
    Unplug and disconnect* EVERYTHING** before an imminent storm or if you leave for 2 or more days.
    * cable/dish too
    ** if you value it, like microwaves, computers, routers, modems, etc
    Merry Christmas
    *all connected w/Premiere ICs
    F1nut Posts: 51,917
    edited December 2016
    xcapri79 wrote: »
    *not to......
    Based on your track record - not to listen to your advice, such as your "reckless equipment maintenance suggestion to a new member."
    Everyone but you knew that was a joke and that you lied to Ken about the PM's between you and I. Hence, the reason I was back in 2.5 days. Oh snap!
    Since you brought up track records. Have you stopped to think why 99.9% of the members consider you a troll and can't understand why you stay here as no one listens to you or even likes you!?!
    F1nut Posts: 51,917
    Just can't help your disruptive behavior, can you.
  • BlueFox
    BlueFox Posts: 15,250
    xcapri79 wrote: »
    sgmsmg wrote: »
    sgmsmg wrote: »
    tonyb wrote: »
    tonyb wrote: »
    sgmsmg wrote: »
    tonyb wrote: »
    There is some poor advice being given. The Panamax M5300-PM has two high current outlets for your amplifiers. I suggest using them.
    Only if you have weak, budget amps. Out of curiosity, I plugged my two amps into a Panamax (the one with a current meter), and it started vibrating and buzzing like crazy. Shunyata power conditioners are designed to not limit current, and will improve the sound of your amps.
  • kharp1
    kharp1 Posts: 3,453
    Why can't we all get along? And in this holiday season as well, makes me sad. I think there are some people in need of a hug.
  • X, needs to hug a nut.
  • Joey_V
    Joey_V Posts: 8,603
    This place is like one dysfunctional family.
  • kharp1
    kharp1 Posts: 3,453
    Well, I should feel right at home!
    voltz wrote: »
    Good match up's there pal. The Black Mesh 12's on the SDA's should sound pretty freakin' good. MIT also does well of course with SDA's. The Satories on the 705's is also a pretty good match up.
    Just for giggles, you should swap them just to see whats what....if you haven't already.
