New install of amp & no sound on rears
kenwood hu
dxi6501s front
db652 rear
boss 5 channel amp pv3700
the first 3 worked fine before installing amp.
now rears have no sound.100% fade to rear = no sound either
wiring kit is 8 guage rockville
i have rcas from hu front to amp channels 1 and 2. not sure which one goes in the red, and which one goes in the white because these ends are blue and black
kit came with a speaker wire that i'm not sure how to hook up, it is double stranded with no color code or markings. do both strands go together in either the + or - or do they separate?
online says from amp to speaker and another says amp to crossover
tried both and no sound but i'm still not sure what part of the speaker wire goes where???
  • NightfallNightfall Posts: 7,545
    Speaker wire goes from amp to crossover then crossover to speakers. The + and - are separate, there should be some kind of marking on the wire to keep it straight, such as a white line running down one of the sides, or just text like the company name and wire gauge. If there is no markings you're going to have to follow it down by hand/eye.
    afterburnt wrote: »
  • I did exactly that. ran the speaker wire from amp channel one to crossover input. writing on one side so i figured that was + and i separated the 2 and connected. my crossovers were already installed and going to speakers and tweeters. with this there was no sound at all. Back up a little bit to the hu. That is first with rcas to amp, correct? absolutely nothing with this set up so i hooked my hu back up to the crossover input and i have sound again in front but none to back. so the way you are telling me isn't working
  • Is this for car audio? Does your amp turn on? If not you need to run a remote from hu to amp (blue wire). If amp turns on but you have no sound you might have a bad rca. Or you might just need to go into the settings of the hu to turn it on.
    Epson 3020 projector. Da Lite screen. Oppo 103. Yamaha CXA5000. B&K 7250ii. HSU VTF2. Def Tech Supercube 4000. Polk Rtia9 CsiA6 FxiA6. Monster hts 2600. Home theater.
    Bedroom consist of NHT model 2 powered by Parasound hca1200ii coming from my computer.
    Stuff laying around. Too much to list but don't want to sell either.
  • @samavi In my experience with Kenwood decks they can have an option to turn the back speakers off by default (atleast for BT Audio it was this way). Go through your HU settings and make sure everything is turned on.
    Living room
    Mains: Paradigm 90P
    Lows: Velodyne CHT12, Pioneer SW-8Mk2
    Power: Marantz SR7000
    Tv: Samsung UHD 55' Curved 4k
    2 Channel Den
    Mains: SDA2B Upgraded XOs and Binding Posts
    Pre: Denon PRA-1200
    Power: Adcom GFA-545
    TT: Pioneer PL510
    Noggin Rockin'
    Phillips L2
    Harman Kardon CL
    Little dot 1+/GE JAN 5654w
    Closet of Dreams:
    Polk RTA11TL
    New Large Advents 25th Anniversary Edition
    Bravo V2/RCA Clear top Conn branded 12AU7
    Yamaha AV-34
Howdy, Stranger!
