WTB : Dreadnaught Avel-Lindberg 800VA
Dreadnaught Avel-Lindberg 800VA or other recommended Dreadnaught. With all the group buying I am jealous and no way I can spring for the big dog !
  • agfrost
    agfrost Posts: 2,473
    You may find someone who has one, but that's a part you can order from A-L directly, with no group buy needed.
    I've got the 1000VA between my 2BTL, but those who've tried both say it's not too great a difference between the two.
    Jay
  • VSAT88
    VSAT88 Posts: 1,314
    Hey thanks, I think I would be more than happy with any one of the Dreadnaughts as I do not have at all. I read that you bought the 1000VA in the Scuba ban thread. Read the whole thread and it took a while. That was an awesome read.
  • MrBuhl
    MrBuhl Posts: 2,419
    A/L is super easy to deal with - Avel Lindberg part # Y236906 isolation transformer. Even the 800VA is a heavy little sucker. I made one up and had both running at the same time at one point, (2b's and 1c's), they both work great... but the 1K is sexy just 'cause.
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
  • VSAT88
    VSAT88 Posts: 1,314
    MrBuhl wrote: »
    Howdy MrBuhel ! Thanks for that part #. Hope you are doing well ! You would not believe what happened to the 194s I got from you... I put in a " known good" pre amp and as soon as I turned on the amp pre amp volume at 0 something happened that caused a loud wide open volume sound thru the SRSs that took out all of the tweeters and damn near my hearing with it...Back running SL 2000s....
