Need very specific help. Receiver and amp for LSi15 and Lsi-c
Nostalgic
Nostalgic Posts: 42
edited November 2016 in Electronics
Price: if I can get by with just a receiver I'd spend up to $300. If I need to buy an Avr and separate amp then $600 max for all.
1. Receiver. Please recommend a specific one. Can I get by with just this? Either way, do I need one rated to 4 ohms or is that only if I don't use a separate amp? Make sure it has preouts for amp. Really would like one with Bluetooth capability.
2. Amp, if needed. I have zero clue about these so need to know specifically what you recommend. I read comments saying you can spend a few hundred and be just fine. What do I get? I just want to drive these speakers without killing my receiver. Please recommend an amp i can buy.
Thanks all!
    tonyb Posts: 33,070
    No receiver in that price range will be capable of driving the LSI's. I don't even know if you can get one with preouts in that price range, even at 600. You'll need preouts to add an amplifier. If your budget is that limited, you should re think your path and maybe move down to the rtia7's or lower.
  • Thanks for the response. I'm going to keep the LSi15's, if I have to bump up my price a bit i will.
    So let me put it this way, what is one if the more inexpensive (relatively) receivers that has preouts?
    tonyb Posts: 33,070
    Since your budget is that tight, I'd suggest buying used. Something like this....
    https://www.audiogon.com/listings/processors-pioneer-elite-sc-63-amazing-surround-receiver-2016-11-06-home-theater-34787-winter-garden-fl--2
    Then you need an amplifier, which also used can be found from the likes of Parasound, B&k, Sunfire, McCormack, and a host of others for around 400-600 bucks. Look on your local Craigslist too, U.S. AudioMart, Audiogon, or right here in our own flea market.
    Then you need 2 rca cables to hook up the amplifier to the receiver. Something of decent quality like Signal Cable analog 2's which are not expensive.
    If you want new all the way around, your talking a couple grand.
  • I'm OK with used if need be and someone can point out a good deal.
    For the amp, I'm looking at Parasound 1200 or Adcom GFA 555 used.
    Finally, I want to add in that I'd really like the receiver to have Bluetooth.
  • Would the pioneer you linked have a preout for the center channel as well? Or do I use one of the surround preouts?
  • What about a Marantz sr5005 for $250? It's 100 W per channel only but does that matter if using separate amp?
    tonyb Posts: 33,070
    Nostalgic wrote: »
    Yes it does, one only needs to look at the back of any receiver your interested in and the preouts will be labeled....if it has them.
    The power of the receiver won't matter much because you'll be using an amplifier. The receiver can then by itself power the center and surrounds. Parasound is a good choice and I might consider that one above the Adcom.
  • skrol
    skrol Posts: 3,445
    Sounds like you are on a budget. The Parasound HCA-1000A drives the LSi15's quite well and sounds great.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • cfrizz
    cfrizz Posts: 13,415
    The Parasound HCA-1500A would be even better.
  • Legender
    Legender Posts: 478
    Bluetooth? You could buy an external device for $30 that will feed music into your receiver. This should open the door for more receivers in your price point that might be a bit older. Don't forget to use an external amp the receiver must support preouts to feed into the amp. I usually look for pictures for any receiver I'm looking at to insure it has preouts.
    Music: Oppo103 - Parasound JC2 - Parasound A21- SDA 3.1
    Theater: Denon 3808 - B&K 7500/Emotiva XPA-3- RTi12, CSi5, RTiA7x4, PSW505
    Sleeping: Marantz 70005 - Harman Kardon 2400 - SDA 2
    2 Channel: Cary 306 SACD - Canary Audio 906 - Pass Labs x250 - PS Audio Perfectwave DAC, Polk LSiM705, SVS SB13 Ultra
    Office: Dell Optiplex, Emotiva XDA-2, Adcom 5500, LSiM 703
    Spares: Yamaha CA-810; LSi 15; Kenwood Basic M2a, Yamaha M60/M80, Polk Monitor 7, SVS SB13 Ultra
  • You guys are very helpful! Much appreciated.
