Ceiling as upper fronts
jimsvm
Hi, the new home theatre is all pre wired for upper fronts above the panasonic 65", I'm going with lsim 706c and the 705's for now. Sides and rears to come. Question is, would it be possible or recommended to use 700ls or the 900ls as upper fronts? Or is it even worth the effort? Arv is an pio elite. Tks
Rec rm vm30 micro pro 3000 akai 2 channel. ht anthem MTX 5 channel anthem P2 statement anthem 325, 8 channel Martin Logan power amp for 4 ceiling ls900 2 and outdoor polks, 2 JL 110’s subs panasonic 65" plasma lsim 705’s , 706c, L200 and Control 4 garage rig monitor 10s crossovers by VR3, dynamat, RDO-194's, new drivers. psw 111 Pioneer 9040 BDP53fd 100 " screen Nakamichi HD projector, and Panasonic 65” plasma.
Best Answer
Front heights are pretty good to have, in my opinion. Just wouldn't recommend putting a lot of money into those speakers. Dialogue will be almost non-existent from these speakers, so timbre matching, while nice, isn't necessary.
If funds are available, I would say add them.
Answers
I will timbre match all, I don't want to pee off the stereo gods. Thanks for your input .Rec rm vm30 micro pro 3000 akai 2 channel. ht anthem MTX 5 channel anthem P2 statement anthem 325, 8 channel Martin Logan power amp for 4 ceiling ls900 2 and outdoor polks, 2 JL 110’s subs panasonic 65" plasma lsim 705’s , 706c, L200 and Control 4 garage rig monitor 10s crossovers by VR3, dynamat, RDO-194's, new drivers. psw 111 Pioneer 9040 BDP53fd 100 " screen Nakamichi HD projector, and Panasonic 65” plasma.
