What do you think of RTiA3 vs TSx330T for HT fronts?
I'm looking for my first set of good HT fronts and center. I was thinking I really wanted FS but the more I look into it I'm not sure I need them. I have an F12 sub that I would imagine I will crossover (I'm still new so I have yet to figure out what the best way to set up everything will be.). Would it be better to go with the higher quality BS or the more full range FS? I think what I'm looking for is tight low mids, rich full mids and highs that come through crisp and clean without being harsh. The F12 has plenty of power to fill in down low. I would get the TSx250C to match the 330's and the CSi3 to go with the A3's (unless there is a better option you can suggest) Thanks in advance!
RTI A5 and CSI A4 or 6. The A6 is a really big speaker. The A5 is a floor stander, so you won't need stands. So the final price is probably less than the A3's. RTI,s are a better sounding speaker than the TSX speakers
A5's are $400/each, which is significantly more. Amazon has the A3's for $278/pair and the TSx330T are $140/each. This is why I was looking between these two specifically. Would it be better to go with a higher tier bookshelf or a lower tier floor standing?
The set up is in my basement which is carpet floors, drop ceiling, and mostly filled with couch. ~250sq/ft and probably 12-14 ft viewing distance. -
http://www.ebay.com/itm/Polk-Audio-RTiA5-CHERRY-2-Way-RTi-Floorstanding-Tower-Loudspeaker-EACH-/361827101450
Just have to no where to look. Polk eBay could be your friend.
Anyway of the 2, I would go with the RTI A3. -
Thanks for the advice! -
The question that is being raised is where r you going to put the A3s? If the viewin distance is 12-14 feet, then you want them at LEAST 8 feet apart, ideally more like 10-12. So you'll need something to put them on. Unless you put them on quality stands, you will compromise the sound quality, which I know from much experience. Good stands cost $100-150 at the low end. So figure that into you budget.
I have never heard the floor standees, but I would think about looking at the signature series before you make your purchase...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Bedroom 2.1 Harmon Kardon HK3490; Bluesounds Node N130; Polk RT25i; ACI Titan Subwoofer
