Kimber Hero v Audioquest Black Mamba's
Anyone here ever compare the two head to head? Debating making a cable change but curious as to thoughts on if it will be a downgrade, upgrade or lateral move.
Thoughts appreciated....
    You know what I'd say....look elsewhere. ;)
  • WagnerRC
    WagnerRC Posts: 2,209
    If you want to try the AZ cables, let me know. no charge for a test ride.
  • Erik Tracy
    Erik Tracy Posts: 4,673
    Aren't the Black Mamba's subwoofer ICs?
    EndersShadow Posts: 17,713
    Erik Tracy wrote: »
    Nope thats the "Black Thunder" lol..... Mamba's are a AudioAdvisor exclusive and supposed to use the same type of copper as the King Cobra........
    pitdogg2 Posts: 27,158
    Erik Tracy wrote: »
    Erik Tracy wrote: »
    they are both exactly the same and both are AA exclusives from Audioquest. Both Audioquest branded Diamondback "Perfect surface" and King Cobra "Perfect surface+" in AA ads they have listed them as "Perfect Surface" and "Perfect Surface+" so pick your poison it is definitely one of the two wires.
    Clear as mud: B)
  • Erik Tracy
    edited November 2016
    I tried the AQ King Cobras - they were not a good match in my system. Sloppy/loose mid-bass.
    And AQ Colorado's were too bright.
    I settled on a used pair of AQ Jaguars - hit the sweet spot on system synergy. They even beat out the MIT Shotgun S3s I tried which were just lack luster, ho hum.
    My suggestion is to go used on ICs: they will have already taken the depreciation 'hit' and you can flip them back at little/no loss.
    That way you can experiment until you hit that sweet spot.
  • sucks2beme
    sucks2beme Posts: 5,689
    I preferred the Kimber over the AQ king cobra all day long.
    The diamondback AQ cables were better in my systems then the
    king cobras as well. I still have one set of Cobras sitting here somewhere.
  • WagnerRC
    I have Kimber and AZ and AZ is the winner for me. Kimber is good for the price.
    Dan, I'd take Bob up on his offer for a ride around the block with AZ 's. I'll lay money, you won't look at AQ or Kimber the same anymore.
    Tony...
    AZ = Acoustic Zen in guessing?
    Yep...
  • Joey_V
    Joey_V Posts: 8,603
    WagnerRC wrote: »
    Maybe I'll take you up one day if that's ok
  • WagnerRC
    You bet Joey. I have lots of cables to play with. Any time.
  • lightman1
    lightman1 Posts: 10,797
    Joey_V wrote: »
    WagnerRC wrote: »
    Cables don't matter, Joey. We've been through this before with you.
  • You looking at RCA or balanced? I'm running Hero's here but they are balanced, your welcome to try them.
    mopar paul wrote: »
    Thanks man. I've got unbalanced Hero's myself, found a set of Audio Advisor Black Mamba's for a decent price hence my question.......
    For now I'm going to hold off though I think...
