digcoax as rca
Willow
Willow Posts: 11,231
can this be done will this affect the sound id I use 2 dig coax instead of a pair of stereo analog cables ?
Post edited by Willow on
  • bknauss
    bknauss Posts: 1,441
    edited October 2004
    Should be A-OK. I've used RCA cables as digi coax before, and when the quality/guage were up to snuff, it worked fine.
    Brian Knauss
    ex-Electrical Engineer for Polk
  • Tour2ma
    Tour2ma Posts: 10,177
    edited October 2004
    Sure it will work as far as being a conduit for electrons... copper is copper, and all that...
    How will it sound? That's for you to determine...
    More later,
    Tour...
    Vox Copuli
  • Willow
    edited October 2004
    english please .....
    :confused:
    is it a very good substitute or should I stick with RCA. the reason I ask is I donlt wanna go buy digcoax if they will not work as well as rca
  • dcarlson
    dcarlson Posts: 1,740
    edited October 2004
    That wasn't english? :p
    I'd keep digital for digital and analog for analog.
    You could give it a try with 2 digital coax if you had 2. If you're going to buy another one just to try, I'd say forget it and use that money for better analog RCA's.
    SDA-2a, Anthem Pre-2L, Anthem Amp 1, MF A324 DAC, Rotel RCD1070
    Senn HD650 Cardas, Mapletree Audio Ear+ HD2, Kimber KS1030, Bel Canto DAC2, M-Audio Transit, Laptop.
  • Tour2ma
    edited October 2004
    adsjvni sdvnin vsknvi vknvnv efomo... :D
    Agree with dc, if a purchase is involved...
    All I was saying is that digital coax will carry an analog signal.. not what they are intended for, but they will do it, i.e., music will come out of those little boxes that make sound...
    The quality of that sound, how well it pleases your ear is up to your ear (or ears, if you are a typical humanoid...)
    Willow, did you get in the cable demo loop when it swung through CA?
    More later,
    Tour...
    Vox Copuli
  • Willow
    edited October 2004
    No I didn't now I'm kicking my self in the A$$ .. I wish I would have it would have given me a chance to either disspell the snake oil theory or believe in it !!
  • Tour2ma
    edited October 2004
    Sign up for the next visit north o' the border....
    Not all went that way in round one and there's at least three separate groupings making the rounds...
    Post in the thread and/or PM doro...
    More later,
    Tour...
    Vox Copuli
  • Willow
    edited October 2004
    thanks I will.
    One last item regarding digcoax, can I use one as my subcable it seems much thicker than the actual subcable ? I think I can but as rule of thumb just wondering
    thanks
    JF
  • Tour2ma
    edited October 2004
    same answer as above...
    More later,
    Tour...
    Vox Copuli
  • Willow
    edited October 2004
