HELP with SDA1c Crossover
Dmac99
I am looking for some advice on a course of action to fix a problem with my SDAs. I noticed that the tweeter on the left chanel was raspy, First fix was RDO upgrade and no change. I pulled out the radiator to look at the crossover and noticed that a piece "2.7 OHM 10% 5W" had fallen off, probably during a move. Does anyone have knowledge of weather this is causing the problem and if so, what outdoor be the best course of cation for someon who cannot solder? New crossovers, rebuild, repair, etc... Any help would be appreciated. Thanks DMAC
Yes, that is a problem. Talk to member Westmassguy about repairing/upgrading.Political Correctness'.........defined
President of Club Polk -
Thanks! I sent him a message.
He upgraded my Monitor 7's crossovers.
I have no ideas or help for the weather outdoors.Does anyone have knowledge of weather this is causing the problem and if so, what outdoor be the best course of cation for someon who cannot solder?
Do you have someone that can help you learn to solder? It's not a difficult skill to pick up, handy, sometimes fun--and entry-level tools along with some supplies would not be expensive.
Thanks, Westmassguy was able to fix the issue. He does great work and is really easy to do business with. Great communication.
