Interconnect cable
kansas1973
Looking at buying a pair of sda's how difficult is it to find the interconnect cable?
The guy wants a 100.00 for them..
Best Answer
Sometimes you can find the cable up for sale on eBay. However you must know which one your speakers use.
Blade/blade
Short pin/blade
Long pin/blade
If you are the do it yourself/upgrade type you can make one. Threads all over this forum with instructions. Or just ask for help.
Great buncha nutjobs on here who will be more than happy to show you how to spend all of your money upgrading
Answers
Welcome to the rabbit hole................uuuuuuh I mean FORUM btw
Thank you!
I feel like these speakers are worth a 100.00
Even if I have to spend 500.00 to get them back on the road.. -
Which SDA's are they?
Short pin.....long pin? Never heard that one before.
OP, what's the model number?Political Correctness'.........defined
President of Club Polk -
Me either, but wasn't sure.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Sorry, been busy the sda's were trash.. He painted them black..
I bought a mint pair of monitor 10bs instead..
They sound great! -
Some SDA's came black from the factory.Political Correctness'.........defined
