Interconnect cable
kansas1973
kansas1973 Posts: 15
edited September 2016 in Speakers
Looking at buying a pair of sda's how difficult is it to find the interconnect cable?
The guy wants a 100.00 for them..
Best Answer
  • honestaquarian
    honestaquarian Posts: 3,260
    Answer ✓
    Sometimes you can find the cable up for sale on eBay. However you must know which one your speakers use.
    Blade/blade
    Short pin/blade
    Long pin/blade
    If you are the do it yourself/upgrade type you can make one. Threads all over this forum with instructions. Or just ask for help.
    Great buncha nutjobs on here who will be more than happy to show you how to spend all of your money upgrading ;)
Answers
  • Welcome to the rabbit hole................uuuuuuh I mean FORUM btw :D
  • Thank you!
    I feel like these speakers are worth a 100.00
    Even if I have to spend 500.00 to get them back on the road..
  • Which SDA's are they?
    F1nut Posts: 51,813
    Short pin.....long pin? Never heard that one before.
    OP, what's the model number?
  • vmaxer
    vmaxer Posts: 5,120
    Me either, but wasn't sure.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • Sorry, been busy the sda's were trash.. He painted them black..
    I bought a mint pair of monitor 10bs instead..
    They sound great!
    F1nut Posts: 51,813
    Some SDA's came black from the factory.
