Tube buffer or DAC?
Been thinking of cheaper ways to increase the sound quality of my 2 channel system. I really don't need a new amp at this time as my integrated has enough power for the room I have the 2Bs in. So I was wondering should I get a DAC or a Tube buffer (pre amp) then run that to my amplifier from my Ipad?
What do you think would yield best results?
    heiney9 Posts: 25,404
    edited September 2016
    A dac would make a world of difference compared to a "Technics something or other CDP"
  • Yeah that is just my CD player. Currently I only have the Ipad going from 3.5mm to RCA on the integrated Yamaha.
    I had a cheap 16 bit DAC I connnected before but it didn't make much of a difference....however it was VERY cheap and not meant for high end audio so that is most likely why. Any good budget DACs out there? $200 or below.
  • Here is a real nice DAC for the money. These are like $500.00 new.
    http://www.usaudiomart.com/details/649299679-parasound-zdac-v2-dacheadphone-amp/
    – Kevin Alfred Strom
  • Great deal indeed!
  • Thorton
    Thorton Posts: 1,324
    heiney9 wrote: »
    +1. Forget the tube buffer for now and get a nice dac for streaming from the ipad.
    DAC: Bricasti M1SE
    Pre/Pro: Marantz AV8805
    Subs: 2 - Rythmik F25's
  • erniejade
    erniejade Posts: 6,321
    You could get a grant fidelity and have both in one.
  • cortico
    cortico Posts: 587
    I was also curious and had a Grant Fidelity tube buffer with a pair of 6SN7 tubes for a couple weeks, I placed it in between a Parasound d/ac1100 and a Marantz 2270 and concluded that I prefer the sound of the dac straight into the Marantz and just sold the buffer.
    I didn't find it useful with my gear, i.e. Parasound players/dac and vintage Marantz...
  • TNHNDYMAN
    TNHNDYMAN Posts: 2,145
    I think a good DAC would serve you best.I would look for a day magic or Peachtree audio DAC-iTx for your budget.
